Sponsored by: Real Truck
E4OD driveshaft e-brake compatibility - diff speed sensor vs. transmission speed sensor
Old Feb 22, 2026 | 01:28 PM
badaimarcher's Avatar
badaimarcher
3rd Gear
Hi all, I have a 1997 E-450 with a 7.3, E4OD, and ZF driveshaft e-brake that doesn't work. The vehicle is a former Red Cross ERV, and based on what the last shop said, someone removed the drum brake pads because users kept smoking them. I'm hoping to remove the entire ZF parking brake assembly, as it is impossible to put new shoes on while the unit is on the vehicle (see video
). The unit I have on the vehicle now is a F7U3-2598-AB with u joint straps on the output and the holes for the transmission VSS:
I purchased a working ZF driveshaft e-brake that came from a 1995 F-Super Duty for $100 (less than the cost of the rebuild kit), but didn't pay attention to the difference in unit number, and while this unit has a hole for the transmission speed sensor, the face plate does not indicate that there is a drive gear within, nor is there a mounting hole to hold the sensor onto the brake assembly.
I obviously want a speedometer and don't want to risk causing issues with the transmission. But here's where things get interesting: there is also a speed sensor on the rear differential. So my question to all of the E4OD experts: can I rely solely on the differential mounted VSS and use my non-VSS brake assembly without issue, or do I need to shell out the extra $$$ for the right AB unit? (option C, https://www.ebay.com/itm/20529751800...TM7V1CPDJTDE24)
Thanks in advance.
Paging Mark Kovalsky
Old Feb 22, 2026 | 03:26 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I don't know the answer to this, but my guess is that the VSS on the axle may not run the speedo.
Old Feb 22, 2026 | 03:50 PM
badaimarcher
3rd Gear
Right on, thanks for answering!
willem_at_work
May 22, 2024 08:33 AM
LittleBlue95
Nov 9, 2023 01:51 PM
bobfromktown
Nov 2, 2007 04:12 PM
thompsontkk
Apr 18, 2005 10:05 AM
