Engine build dates
Old Dec 9, 2003 | 07:17 PM
F250_PowerStroke_Mike's Avatar
Engine build dates
I have a 2004 F-250 SD Crew Cab. The date on the valve cover driver side is Aug 15, 2003. Is this an 03 motor or an 04? VIN is 1FTNW20P14EA55370. Now, having asked this question, what improvements were made in the 04 build?
Thanks in advance for any and all replies.
Old Dec 9, 2003 | 08:10 PM
Buzz Cut's Avatar
Buzz Cut
you have a late build 03 engine [has the good C95 injectors] 04 motors did not go into production trucks prior to Sept 29th 03 [first released 04 motor date from IH]
they moved some components in th 04 changed the turbo a bit in other words they tweaked it
Old Dec 10, 2003 | 09:32 AM
Mark2003's Avatar
Mark2003
Hello,
I have a March 03 6.0 that doesn't get good fuel mileage, my VIN # is 1FTNW21P23EC50908. I was told by my local dealer it was because I was using 15-40 Delo oil. I was also told Ford won't do anything about poor fuel mileage. I get anywhere from 14-17 mpg, mostly around 15.2. I have almost 16,000 on it is there anything I can do to improve this?
I also am thinking of replacing my wife's 7.3 and am a little apprehensive of purchasing a new 6.0. I understand that the injection system is being revamped. Is this true?
Thank you,
Old Dec 10, 2003 | 10:09 AM
emtabmm's Avatar
emtabmm
Originally posted by Mark2003
A: I get anywhere from 14-17 mpg, mostly around 15.2.
B: new 6.0. I understand that the injection system is being revamped. Is this true?
A: That's pretty normal, try a 10w30 and see how much difference you get, also try kepping hwy spd to 70 or lower and don't let it idle for extended periods...
B: Yes...to an extent....
Old Dec 10, 2003 | 04:00 PM
cdtruckn's Avatar
cdtruckn
Hello,
Thank you,
Find another dealer
If I'm not mistaken ford uses delo 400 and bottles it under motorcraft for diesel engine oil.
Old Dec 10, 2003 | 04:38 PM
emtabmm's Avatar
emtabmm
oil is bid out every year, usually a penn crude company (pennzoil or quaker state) just as long as it meets Ford specs....they will not use an expensive grade oil for sure....
Old Dec 10, 2003 | 04:41 PM
cdtruckn's Avatar
cdtruckn
O NO say it isn't SO
Old Dec 10, 2003 | 04:45 PM
emtabmm's Avatar
emtabmm
I regret to inform everyone, but it tis...
Old Dec 10, 2003 | 05:26 PM
skigalini's Avatar
skigalini
Hello,
Thank you,
Oh Mah Gawd! If I were getting 14-17 mpg, I would be down on my knees thanking the Big-G. I get 9.8 mpg. Trust me ... it could be worse ... especially if you were in my shoes.
Cheers,
Enjoy
Old Dec 10, 2003 | 07:17 PM
Diesel Smoker's Avatar
Diesel Smoker
I also have a march- 24- 03 hunstville build date getting between high 14's-17's no problems at 9000 miles never been back to dealer from the date of purchase. And with all these reflash problems I hope never have to bring it in.
old vic
Oct 19, 2004 08:57 PM
tksmitty
2004 - 2008 F150
Sep 14, 2004 02:50 PM
wesran
Aug 6, 2004 04:44 AM
HarleyFisher
Jul 17, 2004 07:58 PM
generoberts
1997 - 2003 F150
Mar 21, 2000 01:01 PM
