Battery Cable Replacement
Old Feb 17, 2026 | 08:09 AM
RigCity's Avatar
RigCity
Have an 02 and it’s time for cables. Truck is starting weak/running out of eletric. Batteries are fresh. Then once turned in no issues.
Planning on 2/0 tinned copper wire, lugs and military terminals. Is it worth using 3/0 to the starter?
passenger side negative has a small ground wire coming off the main crimp. Thinking I’ll make a separate cable to replace that one not a fan of crimping 2 wires in one lug on acct the heat shrink dosent come out as good.
Has anyone done an 02? Seems ~4/5 connections come off the passenger side positive. Any advice or photos would be great.
thanks
Old Feb 17, 2026 | 08:30 AM
INFRNL's Avatar
INFRNL
I don't think it's worth going out of your way to buy a piece of 3/0; just stick with 2/0.
I have an 03 and there are several cables on the passenger side as well as a couple added ones
From memory..there is starter, crossover to drivers, alternator and power to glow plug/ air intake heater relays iirc
Old Feb 17, 2026 | 09:26 AM
FordTruckNoob's Avatar
FordTruckNoob
If you don't already have the tools to crimp your own cables, I highly recommend CE Auto Electric's kit.
Old Feb 17, 2026 | 03:05 PM
callforfire's Avatar
callforfire
If you're gonna diy, go for the overkill. I went 4/0 extreme because I couldn't think of a reason not to.
https://www.batterycablesusa.com/ext...ery-cable-bulk
I will say it is not for tight bends.
Old Feb 18, 2026 | 05:35 AM
MDHunter's Avatar
MDHunter
I will recommend welding cable, finer wires inside so very flexible, and is rated at a higher amperage
Old Feb 18, 2026 | 07:07 AM
Kwikkordead's Avatar
Kwikkordead
I wholeheartedly agree with this recommendation. I used to buy spools of it when I had the shop for building my own cables for whatever. Very flexible makes it easy to route without struggling to bend the cable to fit the area.
Old Feb 18, 2026 | 07:26 AM
Big Horn 2's Avatar
Big Horn 2
Also, don’t forget to consider the starter as part of the equation.
i installed the Power Master 9051. All new 2/0 welding cable (my wheelhouse).
here’s my ‘02:
several things worth noting:
the hand held hydraulic crimper with dies are very inexpensive (I use mine all the time.
in my opinion, use closed lugs not what FORD did with open lugs (see picture and oxidation going leeching into the copper strands on the OEM cable
use marine heat shrink, it has a glue inside the shrink tube to seal it
do a test run with the dies, do not over crimp, it can break the copper strands
welding cable is best practice (that’s my trade)
also don’t forget the crossover positive cable
and don’t forget all of the grounds (motor,frame)
and if you do look at power master starters look at certified dealers, not Amazon or EBay…… there are counterfeits.
Big Horn 2
Old Feb 20, 2026 | 07:00 PM
RigCity's Avatar
RigCity
Thanks for the replies going to start tomorrow. This is a great chance to spend more money building it than buying it lol. At least it will be full tinned copper all around including wire. Should easily last 20 plus years.
thats a nice battery cut off may add one as when the trucks parked I’m not a fan leaving it plugged in 24/7 to a maintainer. Routinely run equipment that has sat generally if the battery was shut off it’s good to go.
Old Feb 22, 2026 | 05:26 AM
Big Horn 2's Avatar
Big Horn 2
RigCity, a battery cut off can be a good idea, especially if there’s nowhere to plug in a battery maintainer. However, in my photo that is a Blue Seas 600A cut off switch for my 17,500# winch power going to the front bumper. I wanted to be able to isolate the power to it in case of a front collision when the winch is not in use👍
I also use the Anderson style plug for other things as well and have an ANL fuse holder where I can swap out different amp fuses.
i should have specified in my original photo. Enjoy your upcoming project🙂
Old Feb 22, 2026 | 10:12 AM
FordTruckNoob
They make awesome stuff, don't they? I have one of their remote cutoff switches and fuse holder in my trailer.
Old Feb 22, 2026 | 12:27 PM
Big Horn 2's Avatar
Big Horn 2
Yes they do👍
Old Feb 22, 2026 | 02:49 PM
B-Rad88's Avatar
B-Rad88
Veteran: Navy
I used these cables about 6 years ago on my 2001 F350 i used to have. I am definitely not as electrically inclined as the people responding, but i personally went to this guys shop when i bought them seeing as I lived in Mesa and was about 10 minutes away. I was planning on using the same kit gain when i change them on my 2002 eventually. They were extremely thick and i coupled this with the Green Sticker Denso starter and my 2001 always started regardless of weather. I believe i started it in -12 degrees without it being plugged in.
Ford - Super Duty F250 F350 Excursion Power Stroke 7.3L, 1999-2003 3/0 (Hard Start Kit) #2300 - Custom Battery Cables
Old Feb 22, 2026 | 02:58 PM
John in OkieLand's Avatar
John in OkieLand
wow, got a dealer just 30 miles from me
West Marine
4317-A South Sheridan Rd
Tulsa, OK 74145
(918) 665-2101
www.westmarine.com
Hyakkimaru
90
Jan 20, 2022 03:36 AM
polarisman729
Sep 18, 2021 09:40 PM
Amicus
Jul 11, 2015 01:09 PM
85F250Diesel
Feb 6, 2010 08:14 PM
jrwhitey_2000
Dec 6, 2009 03:52 PM
