4.6 V8 sub zero no oil pressure
Old Feb 25, 2026 | 08:28 AM
1saxman's Avatar
1saxman
I don't know how much trouble it is on your truck but I would be inclined to drop the pan and check the pick-up screen for blockage.
Old Feb 25, 2026 | 10:08 AM
manicmechanic007's Avatar
manicmechanic007
I'd be inclined to check the main and rod bearings while in there and replace the oil pump, doing a timing job with new tensioners and guides in the process.
You are right, it probably has a clogged oil pump pickup tube from silicone pan gasket material and timing chain guide plastic
Gablucollar
2004 - 2008 F150
Oct 18, 2017 08:14 AM
skidkid
1947 and Older Ford Trucks
Aug 15, 2011 04:31 AM
pintoches
Dec 3, 2010 02:47 PM
rambaseball45
1997 - 2003 F150
Sep 3, 2010 08:48 PM
4point6 expo
Modular V8 (4.6L, 5.4L)
Oct 16, 2004 01:41 PM
