I need help identifying this spindle
Old Jan 24, 2026 | 08:52 AM
Robfrombuffalo's Avatar
Robfrombuffalo
3rd Gear
Hello everyone. Thanks for letting me join.
I bought Frankenstein truck in 2020 of an 18 year old kid who lived in a junkyard. The truck is 99 k1500 lifted 6 inches with 94 f350 rear axle and what appears to be a 79 f250 dana 44 axle in the front. It has 77-79 flat top knuckles and the spindle has been impossible to find. The previous owner or someone a long time ago Hammered it off and left it effed up. So I want to buy new or even used of in good shape. Picture is attached
It is 5 bolt
Old Jan 24, 2026 | 09:26 AM
KULTULZ's Avatar
KULTULZ
Question
No CASTING ID NOS or possible ID TAG on front axle?
Old Jan 24, 2026 | 09:59 AM
Robfrombuffalo
3rd Gear
The axle # is visible but I doubt that the spindle is original. I have been told that there is a serial number on the edge of the flange of the spindle. Is that true?
Old Jan 24, 2026 | 10:11 AM
KULTULZ's Avatar
KULTULZ
Well, here is the problem ...
FORD made it's own parts (some) and some were bought from outside vendors.
If there is any ID on that spindle, please post it.
Can you give the brake size (shoe width x drum inside dia.)?
Old Jan 24, 2026 | 11:10 AM
73 Crew's Avatar
73 Crew
Did a quick google search for a 79 ford dana 44 3/4-ton spindle and there are options for you to check out. Bronco Graveyard was one option. Might also check Ventures Auto parts in Utah for good used Danna axle parts. Good luck with your project and keep us posted with progress on your truck project.
Old Jan 24, 2026 | 11:56 AM
Robfrombuffalo
3rd Gear
I believe I found it. It appears to be a 76-77.5 highboy f250. Link of 1 example https://torqueking.com/products/4033...be2cd1ed&_ss=r Bronco graveyard has same thing I believe but picture is not as good.https://shop.broncograveyard.com/mob...uctinfo/21705/ I'll be calling Bronco Monday. His specs match perfect. 7 1/8 tall 5 hole and 2 inch and 1.675 inch bearing journals. Perfect match. Thank you for your help! Here is a picture of my truck.
My GM truck riding on Ford axles.  American made baby.
Old Jan 24, 2026 | 12:25 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
IMO that spindle is not that bad, I would think a local machine shop could clean it up easy enough. I would just work over that dented area with a file and get it to work. What do you have to loose trying to self repair. Torque King is great place to shop, great place for advice also.
Rock Auto? https://www.rockauto.com/en/parts/us...ub+shaft,15462
Old Jan 25, 2026 | 12:16 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
randys ring and pinion shows they have it, also I have seen a few sqap the entire knuckle to a chevy d44 knuckle and then they use chev 8 lug parts or "outers" as they are occasionally referred to. Obtaining knuckles might be an option.
leehenry
16
Mar 3, 2025 07:11 PM
FuzzyBeanBag
17
Jun 17, 2021 03:54 AM
GatlinDeanWilliams
Jun 7, 2021 09:59 PM
Ouchthathurt
Jul 18, 2016 08:24 AM
jberylecrider
Feb 3, 2003 01:09 AM
