Flat head valve spring question
Old Jan 18, 2026 | 02:36 PM
abe's Avatar
abe
Did Ford switch to non hardened seats when leaded gas became available?
Old Jan 18, 2026 | 03:46 PM
52 Merc's Avatar
52 Merc
Lead has been present in gasoline pretty much from the beginning. The common thought is Ford decided to get cheap and stop installing hardened seats when they invented the rotating valve assembly, which helped keep the valves from pounding in the same place and taking a set.
Old Jan 18, 2026 | 07:49 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Originally Posted by Goshencars
I think you nailed it. Looks like my motor is a 1951 EAB motor with non rotating valves. I feel confident now with the springs I need. Thank you, thank you
Your engine DOES have rotator valves.
Old Jan 24, 2026 | 07:10 AM
Goshencars's Avatar
Goshencars
I checked the lift on my valves and I only had .180-.210 lifts. Fuel pump rod lift was .120. What cams will work? I have found a 7RT-6250 and an EAB-6250. What's the difference? Thanks
Old Jan 24, 2026 | 08:25 AM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
There are many flathead cams with slight differences in the grind - I don't know exactly what those differences are. There is a technical reference here:
https://www.tildentechnologies.com/Cams/CamHistory.html
The 7RT-6250 is not a part I find in any of my Ford documentation. It again seems a culprit of a vendor, such as DC, using a Ford looking part number for some of their items. The EAB-6250 was used in 52 and 53.
Any of last generation cams can be utilized with all the appropriate accompanying components.
Our tucks 239 engines were furnished with 7RA-6250-B, 8BA-6250-A, 8BA-6250-B, and EAB-6250-A.
There are likely markings on your existing cam that can help identify it once uncovered.
Old Jan 24, 2026 | 09:48 AM
Goshencars's Avatar
Goshencars
Thanks I hope to have the cam out this weekend. I'll see what the numbers are before ordering new.
Old Jan 24, 2026 | 06:20 PM
Goshencars's Avatar
Goshencars
I got my cam out today. It was marked EA with the letter A under it. The crank was also marked EA. The rid journal were 2.139 - .020 not 2 ". I assume I can get new bearings for this crank.
Old Jan 24, 2026 | 07:12 PM
bmoran4's Avatar
bmoran4
An EAB-6250-A would be stamped with a "B"
"A" isn't a stamping that I can immediately identify...
Any chance of some pictures?
Old Jan 24, 2026 | 11:27 PM
ALBUQ F-1's Avatar
ALBUQ F-1
This is info I saved off threads on the HAMB and Ford Barn:
50-51 Ford cams are marked B
52-53 Ford cams are marked EA or EAB
49-51 ford "B" cam
.305 lift
int. opens 5*btc - closes44*abc clearance set @.017"
exh. opens 48*bbc -closes3*atc clearance set @.019"
52-53 ford "E" EAB cam
.328 lift
int. opens 21*btc - closes68*abc clearance set @.017"
exh. opens 56*bbc - closes11*atc clearance set @ .019"
Did you check clearance before measuring your valve lift? Your cam appears to be badly worn. The lift for the fuel pump is right in spec.
Old Jan 26, 2026 | 07:16 PM
Goshencars's Avatar
Goshencars
I got the cam out and it looks good. I measured the diameter of the heel and heel to nose and hade over .300 lift. I am not sure why I got lower lift readings off the valves when in the block. I attached pics
66 bronco roadster
Jul 16, 2024 08:57 AM
pinellas50
24
Aug 12, 2012 03:26 PM
F-250 restorer
35
Apr 26, 2011 08:15 PM
fordfan28
13
Jun 10, 2007 03:17 AM
OldSchoolRodz
Jul 18, 2005 11:16 PM
