Broken Valve Spring
Anyway, my real question here is should I be replacing anything else in the name of preventitive maintaince while I am in there? I intend to replace the timing chains, guides, and tensionsers along with all the gaskets involved with such a job. I believe the most cost effective way to go with the cylinder heads are getting a pair of remans. I feel I should replace both heads since I have it torn that far down and can't guarantee a spring on the other head might let go for some reason.
All of this contingent on what I find with possible piston damage from the dropped valve of course.
Well, I guess there is a little assumption there. At 3K rpm or so I don't see how the piston and valve couldn't have made contact. The valve stem would have had to bend on the valve train side in mili seconds for that to happen I would think.
The truck has 110K miles on it and I have never seen any smoke out of the tail pipes. Mabey 1/2 quart oil loss between oil changes if that....it might be closer to none.
I spoke with a cylinder head shop who does nothing but remans. They said they tumble and stress test springs on heads they receive for rebuild. If the springs pass the test the just reuse them. I am starting to think of having them redo my heads and have them install brand new springs....wether it be new OEM or after market. I am in the early stages of tearing this thing down now and I can already tell I never want to do this job again!
Another reason I am asking if there is anything else I should do while I am in there. I'll drop this thing off at the junk yard before I do this job a second time.
Anything else I should look at replacing while I am in there?
Good luck with your project.
Are there any lift points on this motor that might be buried down in there that I'm not seeing? What's the best way to lift it out?
If I had to do it again I would cut the radiator support and remove it like the Excursions are for the extra room to work in.
I also installed electric fans from a V8 Continental LS.
From my manual;
SECTION 303-01A: Engine — 4.6L and 5.4L 2000 Expedition/Navigator Workshop Manual
IN-VEHICLE REPAIR
Intake Manifold —4.6L
Removal
WARNING: Do not smoke or carry lighted tobacco or open flame of any type when working on or near any fuel-related components. Highly flammable mixtures are always present and can be ignited. Failure to follow these instructions may result in personal injury.
Disconnect the battery ground cable (14301). For additional information, refer to Section 414-01 .
Relieve the fuel system pressure. For additional information, refer to Section 310-00 .
Drain the engine cooling system. For additional information, refer to Section 303-03 .
Remove the engine air cleaner (ACL)(9600) and the air cleaner outlet tube (9B659). For additional information, refer to Section 303-12 .
Compress and slide the hose clamp and disconnect the upper radiator hose.
Remove the accelerator cable snow shield.
Remove the bolts.
Disconnect the throttle body cam.
Disconnect the accelerator cable (9A758).
Disconnect the speed control actuator cable.
Remove the accelerator return spring.
Remove the accelerator cable bracket bolts and position the bracket and cables aside.
Disconnect the main vacuum harness.
Disconnect the throttle position sensor and engine vacuum regulator connectors.
Disconnect the fuel pressure regulator vacuum line.
Disconnect the vapor management valve vacuum line.
Disconnect the differential pressure feedback EGR connector.
Remove the nut and disconnect the brake booster vacuum line and bracket.
Disconnect the fuel lines. For additional information, refer to Section 310-01 .
Disconnect the idle air control motor electrical connector.
Position the EGR valve to exhaust manifold tube aside.
Disconnect the upper fitting.
Loosen the lower fitting.
Disconnect the two vacuum lines.
Position the tube aside.
Remove the four bolts and remove the throttle body adapter.
Disconnect and remove the positive crankcase ventilation (PCV) hose.
Position the power steering reservoir aside.
Remove the upper bolt.
Remove the lower bolts.
Position the reservoir aside.
Disconnect the eight fuel injectors.
Disconnect and remove the eight ignition coils. For additional information refer to Section 303-07B .
Remove the generator. For additional information, refer to Section 414-02 .
Disconnect the heater hose.
Disconnect the two radio interference capacitors.
Remove the water thermostat. For additional information, refer to Section 303-03 .
Remove the nine bolts.
Remove the upper intake manifold.
Lift the intake manifold.
Disconnect the intake manifold tuning valve connector. Remove the intake manifold and discard the gaskets.
Remove the bolts.
Separate the upper and lower intake manifolds and discard the gasket.
Remove the bolts and the intake manifold tuning valve.
Installation
CAUTION: Do not use metal scrapers, power abrasive discs or any abrasive means to clean the sealing surfaces. These tools cause scratches and gouges that make leak paths. Use a plastic scraper only.
Clean all the sealing surfaces.
Position the intake manifold tuning valve and install the bolts.
Position a new gasket and the upper intake manifold on the lower intake manifold.
Install the bolts and tighten in two stages in the sequence shown.
Stage 1: Tighten to 2 Nm (18 lb-in).
Stage 2: Tighten to 10 Nm (89 lb-in).
Install the upper intake manifold.
Position the new intake manifold gaskets.
Position the upper intake manifold.
Loosely install nine bolts.
Connect the intake manifold tuning valve electrical connector.
Install the water thermostat. For additional information, refer to Section 303-03 .
Tighten the 11 bolts in two stages in the sequence shown.
Connect the two radio ignition interference capacitor electrical connectors.
Connect the heater hose.
Install the generator. For additional information, refer to Section 414-02 .
Install and connect eight ignition coils. For additional information, refer to Section 303-07B .
Connect the eight fuel injector electrical connectors.
Install the power steering reservoir.
Position the reservoir.
Install the two lower bolts.
Install the upper bolt.
Install the PCV hose.
Install the throttle body adapter and the four bolts.
Install the EGR valve to exhaust manifold tube.
Hand-tighten the fittings.
Tighten the upper fitting.
Tighten the lower fitting.
Connect the two vacuum hoses.
Connect the idle air control motor.
Connect the fuel lines. For additional information, refer to Section 310-00 .
Connect the brake booster vacuum line and bracket and install the nut.
Connect the differential pressure feedback EGR connections.
Connect the vapor management valve vacuum line.
Connect the fuel pressure regulator vacuum line.
Connect the throttle position sensor connector and the engine vacuum regulator connector.
Connect the main vacuum harness.
Install the accelerator cable bracket and the bolts.
Connect the throttle body cam.
Connect the accelerator cable.
Connect the speed control actuator cable.
Install the throttle return spring.
Install the accelerator cable snow shield and the bolts.
Connect the upper radiator hose and position the clamp.
Install the engine air cleaner and the air cleaner outlet tube. For additional information, refer to Section 303-12 .
Connect the battery ground cable. For additional information, refer to Section 414-01 .
Fill and bleed the engine cooling system. For additional information, refer to Section 303-03 .
I found several pieces of broken black plastic down in this valley so I am interested to see what I find when I remove it.
Thanks again Mel.
