6.2L V8 Discuss the 6.2L V8
Differential covers...sealant or gasket?
Old Jan 13, 2026 | 02:38 AM
Qwazert's Avatar
Qwazert
Most manuals and YouTube videos say to use RTV silicone for sealing the differential covers, but has anyone tried using/making gaskets instead?
Is there an advantage to using sealant over a gasket or the other way around?
I used sealant when I did my rear diff a few years ago...but I always have a problem lining up the holes, while lying on my back and supporting the cover....a gasket would be so much nicer.
Old Jan 13, 2026 | 06:33 AM
Jaybird80's Avatar
Jaybird80
5th Gear
Lube locker makes reusable gaskets, I got then for my front and rear differentials and transmission pan and they work great. I believe they were around $30 apiece
Old Jan 13, 2026 | 06:42 PM
2015 F-350's Avatar
2015 F-350
I use lube lockers also
Old Jan 15, 2026 | 07:09 AM
2015 F-350's Avatar
2015 F-350
I really like the lube locker. Here's a thread that goes into all kinds of things, but it seems the lube locker is best called for if you don't have a drain plug on the diff cover. If you have a drain plug, then it doesn't really seem to matter one way or the other:
https://www.ford-trucks.com/forums/1...-sterling.html
Old Jan 15, 2026 | 09:14 AM
Creston's Avatar
Creston
I've used lube lockers but if I install a yukon or similar cover with a drain (like they all should have) i use rtv anymore
Old Jan 15, 2026 | 09:27 AM
Don Ridley's Avatar
Don Ridley
FYI, Permatex makes an RTV specifically for differential covers. It works very well.
Old Feb 1, 2026 | 01:32 PM
Qwazert's Avatar
Qwazert
Gotta laugh at this....
Old Feb 2, 2026 | 04:50 PM
Dairyboy's Avatar
Dairyboy
I got lube lockers to install when I change my diff fluids this spring.
HRTKD
Jul 20, 2020 08:33 AM
ottoparts
Apr 26, 2014 06:04 PM
dohc_chump
Feb 18, 2011 06:05 PM
Sixoh
Jul 27, 2003 05:22 PM
erikl85
Nov 15, 2002 05:47 PM
