Gasket Goo
Old Nov 14, 2002 | 08:16 PM
erikl85's Avatar
erikl85
Gasket Goo
Has anyone tried that silicone gasket maker stuff as opposed to actually buying the gaskets? How does it work. Sorry couldnt think of a better forum and this just happens to be my "home" forum.
Old Nov 14, 2002 | 10:29 PM
LxMan1's Avatar
LxMan1
Gasket Goo
It depends, The factory now uses black goo for geskets like oilpan and valve covers. I prefer regular gaskets with just a thin layer of gasket sealer on one side. Just enough to hold the gasket in place. Plus sometimes you get lucky and can reuse most gaskets this way if they are fairly new.
Old Nov 15, 2002 | 10:35 AM
jim henderson's Avatar
jim henderson
Gasket Goo
A good article in Hot Rod Magazine, I think Nov or Oct issue.
They talk about gaskets, sealers and the form-a-gasket stuff. Pros and cons and where to use stuff. Apparently a lot of changes in technology in the past 10 years or so.
Good Luck,
Jim Henderson
Old Nov 15, 2002 | 12:02 PM
laptopgeek's Avatar
laptopgeek
Gasket Goo
erikl85
Can't beat the yellow weatherstip cement and normal gaskets. I've used it for 35 years and counting.....
PLUS....if something goes wrong pretty soon after a repair, you CAN pull the pan / cover back off with damaging the gasket....
I prefer cork of rubber gaskets, though....
Old Nov 15, 2002 | 05:47 PM
F250NUT's Avatar
F250NUT
Gasket Goo
hambass
Mar 8, 2017 11:12 PM
grears
Apr 28, 2013 08:53 AM
andrew1
25
Nov 11, 2010 08:05 PM
bullofthewoods
Jan 26, 2005 01:18 PM
meck
Oct 25, 2002 05:56 PM
