Black layer in degas
Old Jan 5, 2026 | 06:48 PM
53jimc's Avatar
53jimc
Hi Everyone,
Well, grandson's 05 had a black layer in the degas bottle. Truck used to be mine.
Dummy me immediately thought breached oil cooler. But, there was no emulsion.
I immediately drained coolant but it was clear. There's still a bit in the rad, will finish draining tomorrow.
Why didn't I skim the top to be sure it isn't fuel? Pre conceived notion I guess.
Anyway, I'll put it back and run it a bit to see what I get.
I did check degas pressures, nothing over about 12 psi when warming up from cold and after relief pressure never got to 16 psi.
Engine has over 300k miles, runs great, no smoking, no hard starts.
Once I get it running I'll see if it's oil or fuel. Either way it doesn't sound good.
Lots of work for papa to do.
Old Jan 6, 2026 | 03:18 AM
BLADE35's Avatar
BLADE35
Usually a bad oil cooler cause this blackish stuff in degass bottle
Old Jan 6, 2026 | 06:56 AM
bismic's Avatar
bismic
Combustion gas leaking into the coolant can bring soot with it and if bad enough, that can make a thin layer in the degas bottle.
Old Jan 6, 2026 | 11:01 AM
joe blow's Avatar
joe blow
Man if there is one thing I am sick and tired of doing in the 22 years I've owned this girl, is tearing the top of the engine off.
Hopefully never again
Old Jan 6, 2026 | 12:34 PM
Hartwig's Avatar
Hartwig
You can try using a kitchen towel to soak up the film of oil on the coolant and see if the film returns.
LipRipper3006
Nov 21, 2024 03:01 PM
aslate
May 22, 2023 06:58 PM
tj4ndirish1968
Oct 5, 2021 07:21 AM
tjustice
Apr 23, 2015 04:17 PM
damac
Apr 10, 2010 08:54 PM
