Drivers side window…………
Old Jan 3, 2026 | 04:29 PM
Mr.Lars's Avatar
Mr.Lars
On my 1991 F-350 will not go up, no sound from motor, 12v power all the way to the motor, but no action, switch is good.
I have the inside panel, and sheathing removed, exposing all the access holes, but I can’t see how the motor/gearbox can be removed? Everything worked up fine, until today. TIA.
Old Jan 3, 2026 | 04:38 PM
90project5.0's Avatar
90project5.0
Most likely riveted on, drill out the rivets, bolt new one on.
Old Jan 3, 2026 | 05:14 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Alternate opinion:
Most likely screwed on, drill out the dimples in the door shell to gain access to the screws. Remove the motor and replace the gears inside the motor or bolt new one on.
Old Jan 3, 2026 | 07:23 PM
1Butcher's Avatar
1Butcher
The motor needs power and ground. If there are both, then the motor is faulty. The window could be seized also, which would prevent it from moving. An ohm test would confirm if the motor has excessive resistance.
UnashamedMTBigBlock
Oct 14, 2022 09:31 AM
Scott in TX
31
Feb 28, 2020 08:22 AM
armydad71
Aug 14, 2009 01:53 PM
cnowotny
Jun 27, 2008 04:39 PM
Boz86
Jun 19, 2008 07:36 AM
