power window -- not motor
Old Jun 18, 2008 | 06:14 PM
Boz86's Avatar
Boz86
Ok, lowered power window all the way down yesterday. Must have been thinking bad thoughts because it wouldn't come back up.
Buy new motor. Put motor in. Push button raising and lowering window while admiring handiwork and improving mechanic skills.
Window goes all the way up second time and stops. Won't come down.
Hmmmm. Pull plug, attach to old motor. Old motor turns.
Undo bolts, wiggle new motor, get window to lower. Put back up and leave it there, replace door panel, pondering complete lack of mechanical skills.
Any idea what's going on? My thoughts are there's a stop that's malfunctioning but I don't know enough to begin to guess.
Old Jun 19, 2008 | 02:20 AM
TexasGuy001's Avatar
TexasGuy001
Maybe the switch on the door panel is bad. I replaced all of my door lock and window switches several years ago. Now my passenger one is intermitent and only works after you press it a few times. You can get a new one from Orielly for 10 bucks. I am going to be picking one up soon.
Old Jun 19, 2008 | 06:08 AM
beaners1's Avatar
beaners1
Had a problem like that on my Taurus, found out if I had the motor too tight it wouldn't work. ended up leaving them unplugged.
Old Jun 19, 2008 | 06:52 AM
Boz86's Avatar
Boz86
Certainly worth trying, but the window wouldn't work from either the drivers side or the passenger side switch (it was the passenger window).
Old Jun 19, 2008 | 07:04 AM
60F100's Avatar
60F100
I ahve a similar problem on my 90 F150. I think it has something to do with the stops or motor binding but have not had the time to figure it out. Mine seems to go down to far. Sometimes I can lift the glass and hit the button at the same time and it will work. A real pain when you get caught in the rain. Make sure the mechanism is properly lubricated and that everything is adjusted correctly. These motors are not very powerful. If anyone knows the proper lubricant for windows please let me know
Old Jun 19, 2008 | 07:36 AM
TexasGuy001
Also make sure there is grease on the nylon rollers on the regulator. Any grease will work. I usually just use what ever is in the grease gun. Marine grease would be good since it is less apt to wash away.
