How's this camshaft
Old Jan 2, 2026 | 09:21 PM
idealtrucks's Avatar
idealtrucks
How's this camshaft
How does this cam look? Reusable? It's stock from 351m. The lifters have a good look on the bottom, but I can't tell that they are still convex.
Old Jan 2, 2026 | 10:11 PM
LandAndStone's Avatar
LandAndStone
Desk Jockey
Looks rough. I’d suggest new cam and lifters. If you’re putting the time, effort and money in a rebuild, I’d invest in new hardware. But depends on intended use. If it’s just a farm truck, why not. Daily, no way.
Old Jan 3, 2026 | 09:57 AM
440 sixpack's Avatar
440 sixpack
It's junk.
Old Jan 3, 2026 | 11:39 AM
tbear853's Avatar
tbear853
Just my opinion.
Only if the exact same lifter is used in the same bore above the same came lobe would I trust it longer than short trips from home as a "non essential & not gonna break the bank if it fails" type engine. If you mixed the lifters up, they are scrap now. New lifters on that cam "might" work.
If any lobes are not full, if any are worn on the peaks so as to be closer to round, the cam is scrap too. I looked at the pics, don't see any wiped lobes, but pics aren't like examining it in person. Measure the lobe heights, intake vs exhaust, should be 8 of each, and consistent per usage group.
Old Jan 3, 2026 | 03:45 PM
79F150400M's Avatar
79F150400M
Not a good idea to ever re-use a camshaft... especially one from a 351M. As stated in a previous post...it's junk.
Old Jan 3, 2026 | 05:49 PM
tbear853's Avatar
tbear853
If OEM it's likely made of as good a metal as any of Ford's OEM cams I would think.
Old Jan 3, 2026 | 06:33 PM
79F150400M's Avatar
79F150400M
That's probably true but my thought was coming more from a performance perspective.
Old Jan 3, 2026 | 06:46 PM
440 sixpack
CWC made the cores for nearly all cams for many years, so the only difference is the grind. I believe they ceased production a couple years ago, just one more reason to go with a billet roller cam.
Old Jan 5, 2026 | 11:20 PM
motorsickle1130's Avatar
motorsickle1130
Partial picture on a phone screen over the internet? SEND IT BRO!!! It’ll totally work out!
Sandbaja
May 28, 2022 06:06 PM
DirtyFerd
15
Oct 26, 2020 06:16 PM
FoxFord33
Modular V8 (4.6L, 5.4L)
Apr 2, 2015 10:26 AM
roadrash63
Jul 10, 2010 12:59 AM
