on my 68 f250/360 c.i. when driving on the highway.. the engine went from v8 to a v4 instantly. limped back to the shop........ pulled valve covers and found the rear 4 cylinders were not working!!! Broke down the engine and found a broken camshaft and a crack at the valley. needless to say total rebuild short block.
Wow, I had a 360 that did that while warming up one day. Destroyed a rare rear sump FE oil pan in the process. Block was unusable as the cam section fell down and the crank slammed it into the side of the block.
Dang -- what caused 3/4 of your camshaft to evaporate?
There are a lot articles out there opinionating about today's oils not having zinc or phosphate in them because those items can damage a catalytic convertor and therefore the additives were phased out over time. But as the story goes, older engines especially those with flat tappet cams become susceptible to camshaft failure since there isnt a strong enough oil film between the cam and the lifter at cold startup, which the zinc and phosphate supposedly provide. Here are a few articles -- even Hemmings weighed in:
I think it was just a weak cam. I used the oil with the higher zinc content. The cam bearings looked better than I expected. The cam probably only had 5 thousand miles on it. Maybe not even that.
It may have been dropped sometime between the manufacture and when you got it.
I had a brand new 429 PI cam in the tube that I bought from Ford and had squirreled away for future use and when I opened it I had a 2 piece cam!
Take a close-up picture of the fracture itself from the end. That will often tell you the story of where the problem initiated and how long it took to break. A sudden fracture looks very different than the propagation of a small crack or manufacturer's defect.
