2005 6.0 Superduty hard start after sitting
Old Dec 25, 2025 | 01:07 PM
cokefirst's Avatar
cokefirst
I was told to bring this to this sub forum after posting on the general F250 forum. Ok, here is the background. 2005 F250 Super-duty. I purchased it used from my neighbor. It was 5 years old and had 20,00es on it. For the first few years, it was a headache. I used it to go on long trips each summer, and the first three times I did this. something would fail. I took it to a shop in my area that specialized in these vehicles and for about $3500 - $4000, they seemed to fix the problems. It has run very well over the past 12 years of ownership. I regularly service it, change oil, filters, coolant, etc. It now has 137,000 miles on the clock.
The past couple of months, I noticed that the truck will crank but not start for an extended period of time. I always let the glow plugs warm up until the indicator light goes out. It will normally start up quickly if I start it every couple of days. If I let it sit for a week or more, (I use it sparingly since it does not get good gas mileage) it seems to crank for 45 or so seconds before it fires. I do not want to burn out the starter and am wondering what the problem may be.
In searching for clues, I see questions about the battery. (It cranks fast and the batteries do not appear to be the problem). There is some indication about a high pressure oil pump causing this, sounds confusing to me as I am not familiar with this problem, as oil pressure is good once the truck starts. The other problem may be a failing fuel pump, or the fuel draining back. Since the fuel pump is electric, and sits on the frame rail, I am not sure why it would drain back, since it would have to drain uphill.
The last thing I want to do is just throw parts at it, and would like to know if others have had this problem and what the solution is.
Old Dec 25, 2025 | 02:29 PM
bismic's Avatar
bismic
https://www.ford-trucks.com/forums/1...g-process.html
Old Dec 25, 2025 | 09:01 PM
BLADE35's Avatar
BLADE35
Sounds like it loses fuel or oil prime
post a picture top engine in addition to the info in Bismic post maybe mentioned in that thread not sure
Old Dec 29, 2025 | 05:23 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Get an AE and look at the scopes to see what's triggering it to start. 45 seconds is a long time, way longer than an oil rail bleeding down.
If you pull the secondary fuel filter out of the housing, there is fuel in the housing still, and if you suck that out it refills in a few seconds after cycling the key on, odds are it's not fuel. You can also rule out fuel by letting the pump run to kick off 3x times before trying to start it, then when it still takes 45 seconds it's not the fuel system. The truck will start on very very low fuel pressure, if it runs fine most likely electrical or high pressure oil problems.
https://www.autoenginuity.com/produc...l-bundle-sp03/
cokefirst
Dec 26, 2025 04:03 AM
Wfo1986
May 28, 2024 01:19 PM
6.0boyheadache
Jan 25, 2023 07:39 PM
chapmanst
Sep 4, 2022 04:08 PM
timhall1999
Jul 29, 2018 09:45 PM
