1988 302 build
Old Dec 17, 2025 | 09:35 AM
KeithHires's Avatar
KeithHires
1988 302 build
I’ve recently purchased a 302 Thats been bored over .060… for my 1988 f150 with M5OD transmission Fresh bearings and heads rebuilt. I’m wanting to roller cam swap it. I purchased a 35-320-8 Comp cam to try to keep my speed density setup happy but I’m thinking about returning it and going for a bigger cam with a pimpx computer or Holley sniper.
looking for some guidance because this is my first build.
Old Dec 17, 2025 | 10:31 AM
My4Fordtrucks's Avatar
My4Fordtrucks
‘88 seems to be the conversion year for roller ready blocks so is yours drilled and tapped for the spider? According to Summit Racing those cam specs are for use with 1.7 rocker arms. What heads are you using? What is your plan for the truck? There are a lot of 302 build threads in this forum as well as in the engine forum. In fact there is an ’88 302 build that was brought back from the dead right below this one. Have you read through some of them to see what other people have done? The Pimpx computer is almost $900 and then you need to factor in your ability to tune it. Personally, I would have passed on a .060 over block. From what I read a few years ago that is too much which can cause overheating problems.
EDIT: What are you going to be doing with the exhaust: keeping the stock system, shorties with stock/ aftermarket cat back system or long tube headers with custom system?
Old Dec 17, 2025 | 11:36 AM
torq'ta 5 8's Avatar
torq'ta 5 8
You better read, about Holley EFI, again, that Distributor comes with nothing, EFI, it is only a ignition upgrade $800, then you buy the Holley EFI $1300-1700, then you need a lower intake to slap that carb looking EFI on, now your $2100-2500 into Holley.
Old Dec 17, 2025 | 12:08 PM
KeithHires's Avatar
KeithHires
i didnt know how far over it had been bored till I pulled the heads off after purchasing. I’ve already pulled a spider and dog bones from junkyard truck. And Ive bought new rocker arms with 1.7 ratio to match my cam. I’m worrried about the overheating issues also but might as well run it and see if it becomes a problem then go from there.
The truck is my daily driver. Ive already put long tubes and true dualed the exhaust. I want in time to put some bigger heads but know I’m limited by computer right now so if that means learning how to tune it myself is what needs to happen I’m confident I can figure it out
Old Dec 17, 2025 | 12:36 PM
90project5.0's Avatar
90project5.0
There is always the Holley Terminator X for ford so you don’t have to change intakes. I know a few with them that love it due to not really having to truly dig into tuning. One of them has a twin turbo foxbody. He switched from pimpx to Holley bc he didn’t learn how to tune it.
Old Dec 17, 2025 | 12:51 PM
KeithHires's Avatar
KeithHires
I had looked into the terminator also, and with the price of pimpx they are almost the same money. I don’t have a laptop or any experience with tuning but I also had no idea experience with wrenching until a couple years ago and after pulling engines and transmissions from multiple vehicles I feel I can fake it till I make it
Old Dec 17, 2025 | 01:07 PM
Hit Man X's Avatar
Hit Man X
That cam is fine for a truck, upgrade the garbage E7s if you want to make some actual power and do a smaller cam. You will have a far better time driving it.
The cost of that camshaft is wild, one could have a custom unit ground for less
NO speed density will not like that cam selection, there are plenty of SD compatible cams about if you research...
As stated, verify you have a roller block. My 05/88 did not. Pal's 11/88 did.
These made about 130rwhp stock, what are you after? I would sell that to some fool, 351W swap it...unless you know who actually assembled that unit
Old Dec 17, 2025 | 01:10 PM
90project5.0
I have a system like the pimpx, I had to buy a laptop when I did it. Luckily, I have a buddy that custom tunes with the same program. It’s doable to learn and there are forums and videos on using tunerstudio.
Ive wrenched all my life off and on, but avoided electrics like the plague! It’s been frustrating and and fun to learn at the same time. It’s a challenge.
Old Dec 17, 2025 | 01:17 PM
Hit Man X's Avatar
Hit Man X
Here is a better idea, learn to tune before you jump in the deep end.
Old Dec 17, 2025 | 01:24 PM
Duke5A's Avatar
Duke5A
I don't know if a factory EFI manifold will support 400HP, if it doesn't you'll be in for the cost of a manifold plus injectors. If you want to do it on the cheap side, find a used Edelbrock aluminum 4bbl intake on FBM and slap a Sniper on it. You will need the Hyperspark box, but you can reuse the factory EFI distributor to trigger it.
https://fordsix.com/threads/wiring-t...ark-box.83759/
Old Dec 17, 2025 | 01:41 PM
TheFecalFanatic's Avatar
TheFecalFanatic
Agreed with ASSassin X. I would drop the 302 and go with a 351w block. These trucks arent exactly light and you'll benefit from more Tq down low than the 302 provides. I had an 86 bronco with an EFI 302 and it was gutless.
351w build, stroke it out to a 392 or 408, or go 460.
Old Dec 17, 2025 | 03:00 PM
KeithHires's Avatar
KeithHires
id like to get it to about 300hp in due time. In my research for SD cams I came across a few posts of the 35-349-8 comp cam being able to work with speed density. The 35-320-8 being very similar duration and computer compatible i figured it would also work.
I already have the engine I was gonna use torn down and am $600 in the hole for. I doubt someone will buy it with being so over bored. Finding a roller block 351 would be my ideal situation but working with what I have right now
the block I have is a roller block
Old Dec 17, 2025 | 03:01 PM
KeithHires's Avatar
KeithHires
with the donor engine I bought it came with a brand new dual plane aluminum carb intake
Old Dec 17, 2025 | 03:02 PM
KeithHires's Avatar
KeithHires
how would I be able to learn to tune without psychically having a vehicle to learn to tune on?
Old Dec 17, 2025 | 03:05 PM
KeithHires's Avatar
KeithHires
what heads would you recommend? I’m thinking of just going to junk yard and pulling used roller cam out of late 90s 302 that I pulled my spider and dog bone set out of. Those cams are better than my year model 302 if my research is correct
