Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1966 C600 Vin Tag Info
Old Dec 13, 2025 | 04:09 PM
JasonSpellman's Avatar
JasonSpellman
1st Gear
looking for info on this tag. Thanks for your help.
Year, Make, Model, wheel base, Rear width. Etc.
Old Dec 13, 2025 | 11:30 PM
85e150's Avatar
85e150
C60 = C600 gas
C = 330 2V Medium Duty FT gas V8
U = Louisville Assembly Plant
809446 = 1966 numerical series, January 1966 production.
135 = 135 inch wheelbase
No paint code--truck is a special order and paint might have been part of that.
C600 = C600 gas, 20,000 lbs GVWR
691
6 = Black Vinyl
91 = Tilt Cab
A = New Process model 435 four speed transmission
62 = Rockwell model F-106NX6 single speed rear axle, 15,000 lbs capacity, 6.20 ratio
No front axle code--only optional codes are listed '64 to '69, so standard axle, at least 5,000 lbs capacity, no power steering
20000 = 20,000 lbs GVWR
164 3800 = 164 Certified Net HP @ 3800 RPM
551316
55 = St Louis District Sales Office
1316 = Special Order Number
OK model, WB etc is listed.
Rear width? From the outside of the duals it should be 8 feet. Maybe an inch narrower.
8 foot was the max width at the time. This truck was sold as a cab and chassis, so whatever equipment was mounted on it would be 8 foot wide maximum, with some small allowances for rubber fender flare/mud flap or similar stuff. That equipment would not be supplied by Ford nor of Ford manufacture.
Classiccarlover2008
Large Truck
Oct 17, 2025 09:00 PM
Porkchopwrench
Large Truck
24
May 21, 2025 06:28 PM
Kerns96psd
Large Truck
Jan 8, 2024 05:23 AM
tburden
Large Truck
Jan 15, 2023 10:02 PM
ford highboy!
Large Truck
Jun 29, 2022 11:54 PM
