Need help with figuring out how to decode my f500
Welcome to FTE!
I moved you here as this is the forum for this size truck.
F50 = F500
C = 330 2V Medium Duty FT gas V8
E = Mahwah Assembly Plant
F54599 = 1969 numerical series, August 1969 production
156 = 156 inch wheelbase
N = Dark Green
F500 = F500, 15,000 lbs GVWR
4 81
4 = Black woven thong/corinthian vinyl
81 = With the "4", standard cab. Cab and chassis vehicle
A = New Process model 435 four speed transmission
42 = Rockwell model D-100 single speed rear axle, 13,000 lbs capacity, 6.20 ratio
No front axle code. For model years '64 to '69 only optional axles are listed. Thus, you have the standard Ford axle, probably 4,500 lbs capacity, no power steering. There are numbers on the axles to identify them.
15000 = 15,000 lbs GVWR
164 3800 = 164 Certified Net HP @ 3800 RPM
114753
11 = Boston District Sales Office
4753 = Special Order Number
All the usual suspects are in place on the card--engine, trans, axle, paint. So it's unkown what the special order could be about. Maybe just to get the truck, maybe something else.
Is it a runner?
Check your wheels--this truck could have the widowmaker wheels.
https://www.ford-trucks.com/forums/8...l#post19892682
F50 = F500
N = Dark Green
4 81
114753
Is it a runner?
GaBilgerat
May 21, 2023 07:20 AM
akantler
20
Apr 19, 2023 12:47 AM
Kenneth Maddux
Jun 9, 2021 10:59 PM
