1971 F700 Vin Decode
E = 361 2V FT gas V8
V = Kentucky Truck Plant
L35777 = 1971 numerical series, March 1971 production
174 = 174 inch wheelbase
V = Dark Green
F702 = F700 gas, 23,000 lbs GVWR
4B8
4B = Black Vinyl
8 = Standard Cab, cab & chassis vehicle
M = Clark model 285V five speed direct transmission
E33
E3 = Eaton model 16244 two speed rear axle, at least 17,000 lbs capacity, max 18,500 lbs, 6.50 / 9.04 ratios
3 = Ford front axle, 6,000 lbs capacity, without power steering.
23000 = 23,000 lbs GVWR
182 3800 = 182 Certified Net HP @ 3800 RPM
171475
17 = Washington (DC) District Sales Office
1475 = Special Order Number
The usual special order items are present as regular production items--paint, engine, trans, axle, so the special order was something else.
I do not have the exact rear axle capacity, only a range of 11,000 to 18,500 lbs. Since you have a 6,000 lb front axle, the rear has to be at least 17,000. Only once have I seen a decode where the axles added up to less than the GVWR and I'm pretty sure that was an error. Usually they add up to a little more than the GVWR.
Let me know if something doesn't add up.
What wheels are on the truck? It was still possible to get Firestone RH 5 degree widow makers in '71 so check that out before you fiddle with or even kick the tires.
