Finally Got Me
Old Nov 27, 2025 | 10:08 AM
Byrd.Dog's Avatar
Byrd.Dog
Finally Got Me
Well, it finally happened to me - crank, no start. FICM logic power & main power show 0 on Torque Pro, Cam/Crank sync shows 0 also (IF my PID's are set up correctly). Tach & oil pressure gauge don't move when cranking. Is there a fuse that could kill all of this? Was running fine when I parked it a couple days ago. Only codes are for EGR and Fan (EGR deleted & 7.3 mechanical clutch)
Old Nov 27, 2025 | 10:16 AM
Brotherbillstruck's Avatar
Brotherbillstruck
Are the FICM harnesses fully seated? Good luck with this.
Old Nov 27, 2025 | 12:50 PM
Byrd.Dog's Avatar
Byrd.Dog
Hopefully this is my problem - vermin seem to have gotten to the FICM harness. Found 2 wires chewed through. Have patched them, but waiting to buy some foil tape to re-wrap it. Also recharging the batteries.
Fingers crossed...
Old Nov 27, 2025 | 02:59 PM
Motohead911's Avatar
Motohead911
That is the first that came to mind when you described your issue. Good luck.
Old Nov 28, 2025 | 01:11 PM
Byrd.Dog's Avatar
Byrd.Dog
Yep, that was it. Back up & running.
Old Nov 28, 2025 | 01:20 PM
bismic's Avatar
bismic
Too bad rodents don't follow any set pattern on what appeals to them most under the hood, lol. They can be a real pain.
Old Nov 29, 2025 | 09:11 PM
BLADE35's Avatar
BLADE35
Wasn’t there some spray folks had been spray wiring with a bitter agent or repellent
I found mice been my explorer cabin area recent nothing in trap yet
Old Nov 30, 2025 | 04:00 PM
Baylinerchuck's Avatar
Baylinerchuck
My FIL told me some of the wiring insulation and plastic fuel line is made with corn/ soy products which may explain the rodent fascination with them. I had a vent line on a tractor I could not keep the rodents from eating. I replaced that line numerous times. I finally smeared grease on it and they haven’t touched it since.
Old Nov 30, 2025 | 04:06 PM
bismic's Avatar
bismic
Good idea (as long as they didn't move on to other more-important things to chew on)!
ggenovez
Apr 5, 2024 04:37 PM
ResQmaN
Sep 30, 2022 02:45 PM
Cowboy_in_bfe
May 13, 2013 07:49 PM
1BDTrk
Oct 31, 2005 01:26 PM
