Pcm issues?
Old Nov 2, 2025 | 07:24 PM
Dilburt's Avatar
Dilburt
4th Gear
Pcm issues?
checked the TPS, I was told there would be 1.2 v at middle wire at idle but I'm getting less than 1! And at wide open it read .24! So I pulled the connection at the pcm and checked the continuity and it is good.So based on no tach, OD light on, no voltage to TPS, and couldn't get code reader to communicate with truck does that mean the pcm is bad?
could there be a short to ground somewhere that I cant visually see? If so how do I find it (there were mice in this truck at one point)
Old Nov 3, 2025 | 07:50 AM
Olds64's Avatar
Olds64
I thought only the OBS trucks had a control module and it was for the E4OD? What symptoms does your truck have?
Old Nov 3, 2025 | 07:55 AM
Dilburt's Avatar
Dilburt
4th Gear
The overdrive light is consistently on, it doesnt shift correctly, no rpm on the gauge cluster and it does have the E4OD
Old Nov 3, 2025 | 02:17 PM
tecgod13's Avatar
tecgod13
The rpm (tachometer) gets its signal from the sensor screwed into the injection pump gear housing. The sensor is next to wear you add oil at the top from of the engine. Should have 2 wires coming out of it, They are known to fail. The transmission can't shift correctly without the tach signal, and I believe the OD light constantly on means the transmission is in limp mode. There is a way to read the codes, but I don't recall how.
Old Nov 3, 2025 | 03:18 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The OD light just on usually means the TCM isn't working. If there are codes stored the light will flash.
Here is how to read the codes: www.troublecodes.net/ford
Old Nov 3, 2025 | 06:57 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
If you were to read codes, you for sure would be getting at least the tach and TPS sensor codes and undoubtedly code 62 to go with it.
The first thing you need to do is ensure the fuses and relay are good. You didn't say which year truck, but this one shows both.
If you have a 92-94, be sure fuses I and U are not blown. For pre '92 trucks, just check all your fuses.
Old Nov 4, 2025 | 08:36 AM
Olds64's Avatar
Olds64
Make sure you double check your ATF with the engine HOT. I've read on our forum before that there isn't an E4OD in the salvage yard anymore that wouldn't need a rebuild first. 😕
Old Nov 4, 2025 | 07:46 PM
ToughOldFord's Avatar
ToughOldFord
Trailering
That's nearly the factory setting for the E4DOA
Old Nov 6, 2025 | 03:20 PM
FORDF250HDXLT
This isn't a fluid level issue. The E4OD is electronically controlled and he has no tach sensor and his TPS sensor is reading way out of wack. The trans simply cannot function properly without these inputs. A fresh reman swapped in it's place with perfect fluid level wouldn't even function 1% better.
Old Nov 6, 2025 | 05:27 PM
Olds64's Avatar
Olds64
DOH!
Siresword
Jan 17, 2025 07:25 PM
Drew93OBS
29
Jun 6, 2022 08:49 PM
lonewolf_
May 29, 2019 05:09 PM
PNW350SD
Oct 4, 2016 03:24 PM
Iceman5192
1997 - 2003 F150
Aug 15, 2013 09:54 PM
