‘91 7.3L overheating?
Old Nov 2, 2025 | 09:15 PM
Mr.Lars's Avatar
Mr.Lars
Past couple days the ‘ol girl has been running a bit warmer everyday. Needle on dash gauge normally is between the ‘O’ and ‘R’ on normal. Last couple days, pulling the camper home, the needle gained a full letter everyday. Today is was pegging on the far side of ‘L’ for most of the day, never exceeded 60mph, on the flat, and downhill needle would fall back to ‘A’, and incline back to ‘L’ , then finally late this afternoon would hang just past ‘L’ for a few miles, doing 40mph, then bam, the needle would fly way past the ‘H’ and the Red dash. Let off on accelerator coast to the shoulder, let idle 5min or so, needle returns to the lower ‘cooler’ side of ‘A’.
Overflow tank never filled up, radiator never steamed over, only 1 time did the ‘engine’ icon illuminate on the dash. All fluids are at normal level. Engine sounds as normal as always. We are traveling out town, on our way home, 225 miles to go.
What would be a good place to start have unknown to me mechanics take a look at/test? Fan belt is tight. TIA
Old Nov 3, 2025 | 04:12 AM
tjc transport's Avatar
tjc transport
i ain't rite
my bet is a faulty sending unit for the gauge.
i installed a mechanical temp gauge within a year of buying my 88 for the same reason. gauge saying overheat, but radiator was only 175 degrees by ir thermal gun.
Old Nov 3, 2025 | 06:57 AM
WCMtn1990's Avatar
WCMtn1990
If both your dash gauge and the over temp light were illuminating then you might have a problem sine two sending units failing simultaneously seems unlikely. But if it were just one gauge affected I would lean towards sender failure.
I wonder if the thermostat isn't fully opening? A $33 Equus mechanical temp gauge from NAPA would be a great way to know if you're actually over-heating. Thermostat should begin to open at about 192F and reach fully open at 212F,. If it should turn out to be the thermostat be sure to insist on using a Motorcraft thermostat.
Old Nov 3, 2025 | 10:24 AM
Mr.Lars's Avatar
Mr.Lars
Got into a shop, a couple blocks from the RV park, engine gauge slowly increasing but upper radiator hose stayed cold, heater hoses got hot and heater kicks out heat. Definitely the thermostat, by the time the stat opened, radiator cap released into the overflow tank, first time that has happened. New thermostat and gasket on order.
Old Nov 3, 2025 | 12:27 PM
WCMtn1990's Avatar
WCMtn1990
You might ask the shop to just drain out all the old coolant and refill with FleetCharge unless you know the coolant is fresh. There are 2 block drains, one on either side of the engine.
Old Nov 3, 2025 | 02:30 PM
Mr.Lars's Avatar
Mr.Lars
Coolant is fresh, earlier this year. I changed it myself. Previous Owner had converted to the ‘Red Stuff’. I thought about going back OEM green, but figured why spend all that time and effort multiple times flushing to get all residual coolant.
Old Nov 4, 2025 | 08:44 AM
Olds64's Avatar
Olds64
Hopefully that thermostat gets you on the road.
I'm not sure what "red stuff" coolant is. Is it compatible with the OE green coolant?
Old Nov 4, 2025 | 10:40 AM
tjc transport
i ain't rite
red stuff is a term used for extended life coolant.
Old Nov 4, 2025 | 11:06 AM
Olds64's Avatar
Olds64
The Peak extended life coolant I get from Sam's Club is yellow. It says right on the bottle that it's compatible with all coolants.
https://www.samsclub.com/ip/13602603777
I'd just worry about compatibility. Especially with the 7.3l tendency for cavitation with the wrong coolant.
Old Nov 4, 2025 | 07:51 PM
ToughOldFord's Avatar
ToughOldFord
Trailering
X2, has to be a Motorcraft T-Stat. All of the aftermarket one's I've seen have broken open.
Old Nov 4, 2025 | 10:39 PM
Mr.Lars's Avatar
Mr.Lars
would have preferred a Motorcraft original but, as we are in Van Horn Texas, and all there is here is a NAPA, with the nearest Ford dealership is well over 100 miles, my options were slim. Next stop is my Son’s house for a couple days, then the final leg home. ‘Fredrick’ will be due for a lube, oil, & filter when home, will acquire an OEM stat at that time.
Old Nov 4, 2025 | 11:10 PM
ToughOldFord
Trailering
Old Nov 5, 2025 | 06:46 AM
Olds64's Avatar
Olds64
That would definitely cause a problem.
Old Nov 5, 2025 | 08:34 AM
WCMtn1990's Avatar
WCMtn1990
I would still suggest looking into a coolant temp gauge with a numerical output. I know it's "one more thing" but every time I add a gauge that actually tells me what's going on I wonder why I waited so long.
Old Nov 5, 2025 | 02:25 PM
BigBlue2's Avatar
BigBlue2
is that a motorcraft thermostat? Seems skimpy.
