Auto Hotspot Connection
Old Oct 26, 2025 | 05:41 PM
caward's Avatar
caward
4wd Low
I have a 2024 F-250 Lariat with the vehicle hotspot. Sometimes my iPhone connects automatically to the hotspot, and sometimes it doesn't. I can force the connection by going into my iPhone wi-fi settings and selecting the vehicle hotspot. The inconsistency is driving me a bit nuts. I'd like for my iPhone to automatically connect to the vehicle hotspot.
I've toggled a few things on and off (e.g. auto join on the iPhone settings), but nothing seems to get me to where it consistently connects automatically.
Advice?
Thanks.
Old Oct 27, 2025 | 09:43 AM
23F250ID's Avatar
23F250ID
One of the Few
Veteran: Marine Corps
It won’t connect if you are using CarPlay. I turned CarPlay off and mine works great now.
Old Oct 27, 2025 | 10:27 AM
caward's Avatar
caward
4wd Low
Thanks, I learned that pretty soon after I got the truck. I don't have car play on.
Old Oct 27, 2025 | 10:29 AM
caward's Avatar
caward
4wd Low
I've also toggled the hot spot off and then on via the truck display screen.
Old Oct 28, 2025 | 05:53 AM
99powerstrokedF250's Avatar
99powerstrokedF250
The question is, unless you're on a very limited data plan for your phone, why would you WANT your phone to connect to the vehicle's hotspot? It's an extra fee/plan you have to pay for on TOP of your phone, and your phone likely has better service anyway.
I never bothered setting up the hotspot on any of our vehicles, because for $10/month on top of our unlimited plan (because we're on the go a LOT, especially me), my phone is activated as a hotspot for any device we have that ISN'T connected to cell service. That's considerably less than what I was quoted for the hotspot on the truck.
Old Oct 28, 2025 | 09:08 AM
caward's Avatar
caward
4wd Low
I’m sorry, if you reread my original post, your reply really wasn’t the question at all. How I choose to use the tech and spend my money is none of your concern. Have a great day.
Old Oct 28, 2025 | 09:21 AM
99powerstrokedF250
Except it is - the mobile hotspot in the vehicle is essentially a duplicate of what you already have and are paying for with your phone, at a more expensive rate, and causes other connectivity issues to use it. The ONLY reason I would consider using it (and even then, likely not), is if my employer owned the vehicle and had the hotspot active, and I wanted to use their data instead of my own - again, IF I had a very low data plan on my own phone.
Frankly, while mobile hotspots in a vehicle were a decent idea when they came out, with how phones have advanced, there's not really a need or reason for them anymore, and aside from connecting the vehicle to FordPass, they could be removed.
Old Oct 28, 2025 | 10:13 AM
roadpilot's Avatar
roadpilot
Originally Posted by 99powerstrokedF250
Except it is -
Except it isn't.
His question was about auto connecting to the hotspot, NOT a request for opinions on whether a monthly data plan for a vehicle's mobile hotspot is more financially economical than his phone's data plan.
Wrong again. You don't need a WiFi plan for your vehicle's mobile hotspot for FordPass to work. FordPass needs the (no additional cost) data connection utilized by the TCU (telematics control unit).
For the record, there are times and conditions when the vehicle's mobile hotspot gets a BETTER signal than a cell phone inside the vehicle. This is not due only to technical or environmental differences but also based on your location and the location of the closest cell towers and the carriers serviced by that closest tower.
Old Oct 28, 2025 | 06:27 PM
Smokeatrr's Avatar
Smokeatrr
my cell phone is verizon and my truck is att, When I was in Alaska att worked better
Old Oct 28, 2025 | 07:23 PM
roadpilot's Avatar
roadpilot
Not long after I posted my last message, our power went out. Apparently, the Verizon cell tower in our area was also down. I pulled my new truck out of the barn, fired up the vehicle's ATT wifi hotspot (1st year of service is free), and was able to connect my phone and access the web.
Old Nov 1, 2025 | 06:33 PM
caward's Avatar
caward
4wd Low
UPDATE: Not long after my original post, the WiFi hotspot completely stopped working. I did the Sync 4 reset and the FordPass master reset—neither fixed the issue. I just got off the Ford support line; they were able to determine that the internal modem experienced a disconnect, which would stop the WiFi hotspot from working. There is nothing they can do from their end and said i need to take it to the dealer as it’s a hardware problem with the internal modem.
Fortunately, the dealer is just up the road, truck is under warranty, and I can live without the hotspot for a while.
Old Dec 19, 2025 | 09:17 PM
caward's Avatar
caward
4wd Low
UPDATE UPDATE;
Picked up my truck today from Capital Ford in Carson City. Only took 1.5 days to diagnose and fix, although it took near 5-6 weeks to get an appointment. Not a big issue for me, so the delay-to-service time was bearable. Actual service time (drop-off to pickup-up was great).
Lot of gobblety-gook to me, but I take it that one of the OTA updates did a number on the internal software. Seems to be working fine just now, although there are a number of settings and screens that I need to reconfigure to my preferences
I'm just glad that they didn’t have to tear apart the dash to fix this issue.
CUSTOMER STATES THAT THE HOT SPOT IN THE VEHICLE WILL NOT WORK, THEY CONTACTED FORD CUSTOMER SERVICE AND THEY TOLD THEM THERE WAS AN INTERNAL CONNECTION ISSUE. PLEASE CHECK AND ADVISE.
TECH 002512044-VERIFIED CUSTOMER CONCERN, FOUND HOTSPOT NOT WORKING. PERFORMED EEC TEST, FOUND DTC U211B:51:OB HAS SSM
53759 FOR Trusted Real-Time Operation Network (TRON) Module Authentication DTCs. TCU IS MISSING AUTHENTICATION CODE AFTER OTA UPDATE. NED TO PERFORM TRON DIAGNOSTIC AND REPAIR.
TECH 002512044-HOOKED UP SCAN TOOL AND PERFORMED TRON AUTHENTICATION MISSING MESSAGE PROCEDURE, RAN DIAG AND REPAIR. REPAIR WAS SUCCESSFUL, CLEARED DC'S, NONE RETURNED, WENT INTO VEHIC LE HOTSPOT AND TURNED ON, HOTSPOT IS NOW WORKING, REPAIRS VERIFIED, ALL OK AT THIS TIME.
Hwk-I-St8
2021+ F150
Dec 20, 2023 12:55 PM
GM in a Ford
Apr 23, 2021 03:45 PM
TrippinStfflr
Dec 22, 2017 08:53 PM
Komet86
Ford In-Vehicle Tech
Sep 17, 2017 10:01 AM
