I have a 2025 F350 PSD with electric brake controller. My boat trailer has surge brakes that activate when I back up. It makes backing up on a gravel driveway almost impossible. My boat mechanic has no such issue when he hooks up his tractor to push it around his facility. So today I tried to test to see if any voltage is coming out of the brake controller output pin. Looking at the back of the truck that pin would be the bottom pin of the 3 on the right side of the outlet according to the diagram I have. The ground pin is directly across from it, the bottom pin on the left side. So I put a weight on the brake pedal so I see the brake lights on, turn on the ignition & put the meter leads on the pins & I get nothing. I tested the meters on my battery to make sure they were functioning. Am I doing something wrong or do I have an issue with my truck wiring? Suggestions? Thanks (I had the same issue on my 2017 F350 & assumed it was a boat trailer issue until the boat shop had no problem)
Surge brakes are deactivated with the Reverse light from your vehicle. So you should be checking to see if you see 12V on the center pin of the 7 pin connector when your vehicle is in Reverse.
I thought surge brakes worked on hydraulics, not electric. The whole point on boat trailers is to keep electric brakes out of the water when launching or retrieving a boat.
It has been years since I have used a trailer with surge brakes but recall a pin is inserted in the braking mechanism on the trailer to lock out engaging the master cylinder. This allows backing uphill without activating the brakes. A tractor pushing around the trailer on level ground may not apply enough force to activate the brakes.
Edit: I understand there are versions with electric lockout in addition to the mechanical lockout that I remembered.
My boat trailer has both mechanical lockout & electric lockout. The mechanical lockout, however is poorly designed. The part that fits in the slot to prevent braking more often than not falls out of the slot or won’t fit into the slot to begin with. Very frustrating!
Have you tried backing without being plugged in?
Does it free wheel in reverse until you touch the brakes? Drum brakes do not work as effectively in reverse as they do going forward.
Have two boat trailers I occasionally pull and have no issues backing them up gravel driveways. Don't use the mechanical lockout either. Occasionally there is one bump that will give me some trouble, but hitting it just a bit slower makes it a non-issue.
I haven’t tried not plugged in. The surge brakes activate by merely putting the truck in reverse & pressing on the accelerator even if you go as slow as possible so no it does not free wheel at all. On pavement the truck is able to push hard enough to overcome the trailer brakes. On gravel the truck spins out & starts throwing stones.
Sounds like your surge brakes are set a little too sensitive. Not really sure how to adjust, but there should be a way to lighten them up. You should be able to back up on a gravel driveway without the tires locking up. I've never encountered this issue with ANY trailer with surge brakes before, and I've been towing for 30 years.
Most common surge brakes now have a solenoid activated by reverse lights to stop the brakes from being applied when backing up. in this case, it sounds like the solenoid is not getting power for some reason. As others have mentioned, there is usually a manual lockout in the event the solenoid isnt functioning.
Ask me how I know all this? I had to replace the solenoid on my boat trailer this summer for the same problem. Couldnt easily backup.
To the OP, your brake controller plays no part with surge brakes, it is strictly a hitch activated system based on the weight of the boat.
