Installing a trailer brake controller
Old Aug 15, 2023 | 01:18 PM
shelhart's Avatar
shelhart
1st Gear
I'm new here and could use the help.
Our truck does not have a trailer brake controller. Can I just have one installed at the dealer?
We've got a 2016 F150 and I've towed alot of small things with never a trailer with brakes. Trailer lights work, does that mean I have all the wiring I need?
Thanks in advance.
-Mark
Old Aug 15, 2023 | 01:30 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Does your truck have the 7 pin connector at the back bumper? If so have someone press the brake and test for 12v on the brake pin in there.
Diagram of plug: https://www.google.com/search?client...ruck%2Ftrailer
Old Aug 15, 2023 | 05:12 PM
SpencerPJ's Avatar
SpencerPJ
Yes, your truck will be prewired, and the Dealer can easily install one. Best way to go (unless you are handy and have Forscan.)
Old May 13, 2024 | 12:34 PM
OldSkool77's Avatar
OldSkool77
1st Gear
Hello All,
I know this is an older thread but I was looking for help on a trailer brake controller issue on a 2019 F250. The gain control on the factory controller went down to zero when I pressed the "+", and now it wont move from zero. The trailer wiring harness under the truck looks clean (FWIW) as does the plug behind the 7 pin connector. Trailer brakes work when I apply 12v with PowerProbe (truck disconnected). Trailer lights work, and the truck recognizes the connected trailer. I tried connecting positive and negative at 7 pin to light bulb and applying the brake, but got nothing (not sure if that test would work anyway).
I also tried another trailer that I know doesnt have issues, and had the same problem.
Any help would be greatly appreciated.
BigRiig
All Things Towing
15
Feb 5, 2023 07:26 AM
HRTKD
Oct 31, 2021 09:04 AM
6door74
Nov 1, 2017 09:58 PM
seventyseven250
All Things Towing
13
May 22, 2017 09:24 PM
F150elc01
2009 - 2014 F150
Feb 19, 2014 03:42 PM
