Wiring Help
Old Oct 13, 2025 | 05:23 PM
Voh's Avatar
Voh
Wiring Help
I have the master wiring diagrams, but I found a dead-end. The highlighted area is a red-green wire, red white wire and white-red to connection C-220. the red-green continues on to the coil. What are the other two wires for? how do i fin them on schematic?
VOH
Old Oct 13, 2025 | 07:46 PM
JimsRebel's Avatar
JimsRebel
The coil power source, C-220, is fed from 2 different places.
1) the resistor wire, which starts near the ingition switch mounted on the column.
So look on the diagram for a RUN output that ends up at C-220
2) the coil gets full voltage, Bypassing the resistor wire, to give a start assist while crank the engine. This comes from the "I" output stud on the starter solenoid. This should end up at C-220.
This is just general info, but it might help you find what you are looking for.
Jim
Old Oct 14, 2025 | 08:42 AM
Voh's Avatar
Voh
1) the resistor wire, which starts near the ignition switch mounted on the column.
Jim
Thank you Jim. I was thinking that was what the (2) different red wires were. What about the white wire off that same plug?
Old Oct 14, 2025 | 08:57 AM
Voh's Avatar
Voh
Is the voltage to the coil though the resistor obviously lower than 12 volts? Like single digit vs high 11 volts? I need the 12 volts to the coil the whole time, not a reduced voltage.
Old Oct 14, 2025 | 09:28 PM
JimsRebel's Avatar
JimsRebel
Not sure about the white wire.
Why do you need 12 in RUN?
Is this a DS2 system?
Jim
Old Oct 15, 2025 | 07:59 AM
Voh's Avatar
Voh
It is not a DS2 system. its a small cap pointless replacement distributor.
Old Oct 15, 2025 | 10:17 AM
JimsRebel's Avatar
JimsRebel
You will have to bypass the original resistor wire or use a relay to get full voltage. The instructions that came with your replacement dist. should have more details.
Jim
Old Oct 15, 2025 | 10:19 AM
Voh's Avatar
Voh
Thank you Jim.
JimsRebel's Avatar
JimsRebel
Also, as it's a small diameter cap, keep the spark plugs gapped the same as points. Or about.033 or so.
Jim
vanspeed
Jun 14, 2025 04:12 PM
moto_hero
Jun 2, 2025 08:11 AM
rupp.jess
Mar 9, 2025 07:01 PM
tacticalturnip
Feb 12, 2023 09:09 PM
N8RdaGR8R
Apr 6, 2019 01:52 PM
