Hard start when cold/low power
Old Oct 4, 2025 | 04:45 PM
bigcountryvet's Avatar
bigcountryvet
Trailering
89 F250 4WD 5.8 liter EFI, 300K
Truck is slow to start in cool/cold weather (starts and stutters after 3-4 cycles of the ignition). Starts fine in warm weather even when engine is cold. Starts fine after it has been warmed up. No check engine light and only code is 11 and 33. Also, the engine isn’t putting out normal power. It will just maintain speed in 5th gear on flat ground if no head wind…gutless wonder. The motor does not use oil or smoke. I replaced both fuel tanks with new pumps and fuel pressure is within range. I have replaced some vacuum lines. Where do I begin to diagnose the starting issue? Thanks a bunch!
Old Oct 4, 2025 | 05:53 PM
Junktownbill99's Avatar
Junktownbill99
Check all the vacuum lines and fittings for leaks. And even though the parts are new, check your fuel pressure, at idle and under load.
Old Oct 9, 2025 | 07:13 PM
bigcountryvet
Trailering
Hard cold start
Update. I have checked every vacuum line and tested with brake cleaner and can’t find a leak. Both fuel tank pumps, high pressure pump, filter are all new and fuel pressure is good at start and load. Truck starts fine when warm but slow to start when cold. No codes. Where do I look next ? Thanks
mediaman67
Aerostar
Oct 11, 2014 01:42 AM
Restlesswildman
Dec 8, 2013 11:13 PM
daddykitty
Nov 12, 2012 10:50 PM
PAVEMENTMAN
18
Mar 18, 2008 06:50 PM
captaincook
Jun 3, 2007 03:54 PM
