Shifting problems
Old Sep 27, 2025 | 11:51 AM
jacob19994's Avatar
jacob19994
Trailering
Shifting problems
I have a 1996 f-150 xlt 4wd 5.0 and I am having problems shifting. The 1-2 shift is harsh and when it shifts to o/d it will rev up and float a bit then shift in to o/d. When you let of the gas in o/d it will downshift into 3rd. I just had a new transmission put in it two weeks ago and it worked fine for a little over a week. Also if you floor it it will go up to the rev limit in 1st gear and will just stay there till you let off the gas then it will shift. If you barely get on the gas if will shift through the gears fine but it takes like 2 min to hit 60 that way. Does any one know what could be happening?
what I have replaced.
TPS
I tested the MAF and it was good
mlps and adjusted it
speed sensor in the transmission.
Old Sep 27, 2025 | 02:21 PM
88n94's Avatar
88n94
Did your replacement(new) transmission come with any kind of warranty?
Old Sep 27, 2025 | 03:31 PM
jacob19994's Avatar
jacob19994
Trailering
The new transmission is from jasper engines and transmissions and the warranty is 3year/100,000 mile.
Old Sep 27, 2025 | 04:28 PM
88n94's Avatar
88n94
I would contact whoever you paid for the transmission and tell them of your problem.
Old Sep 27, 2025 | 05:17 PM
jacob19994's Avatar
jacob19994
Trailering
I have already contacted them and they said it was most likely a electrical problem with the pickup up and it have it diagnosed first.
Old Sep 27, 2025 | 09:27 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The first thing to do is to read the codes.
I recommend Forscan. You can download it free at www.forscan.org. You don't have to buy a license just to read codes. Their page shows how to select an OBDII port adapter. I bought mine from Amazon for about $30.
Old Sep 27, 2025 | 09:32 PM
jacob19994's Avatar
jacob19994
Trailering
I have a obd2 code reader. One is a innova 3100 abs and the other is a innova 3210rs. I tried both of them and the only codes is p0443,p1409,p0141, and p0417. I am not worried about those because they are emissions and they have been removed.
Old Sep 27, 2025 | 09:35 PM
Mark Kovalsky
I don't know if either of those are capable of reading Ford transmission codes. Many readers cannot read them.
Old Sep 27, 2025 | 09:38 PM
jacob19994's Avatar
jacob19994
Trailering
ok I have a friend with a snap-on souls Ultra eesc318 that should be able to read it. I will borrow it here soon and see what comes up.
Old Sep 28, 2025 | 01:46 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Is that the same problem you had before you had the transmission replaced?
Old Sep 28, 2025 | 07:16 PM
jacob19994's Avatar
jacob19994
Trailering
No, before I had the transmission replaced it would no go over 35 without putting it in 2nd on the column even though it did shift all the way into o/d
Old Sep 28, 2025 | 07:31 PM
jacob19994's Avatar
jacob19994
Trailering
I did forget to mention that the transmission did get up to about 220 while hauling the trailer.
zman764
1997 - 2003 F150
Jun 15, 2023 06:57 AM
bow66
Escape & Escape Hybrid
Jul 30, 2013 06:04 PM
reel_scream
Oct 18, 2004 08:58 PM
aschwartz
Aug 2, 2003 09:44 PM
eakanator
13
Jul 9, 2002 01:22 PM
