On Board Air Help
Old Sep 27, 2025 | 06:47 AM
cwsartain's Avatar
cwsartain
6th Gear
On Board Air Help
I currently have the WirelessOne air compressor from an airbag setup I had on my other truck. I don't plan to put airbags on this 2022 F250 SRL Shortbed. However, I would like to use the compressor to feed a 2.5 Gal tank I can put underneath the bed and use for OBA.
What all would I need to make that compressor work with the Viair 2.5 tank. I would like to run lines to the rear bumper and front bumper with quick connects.
Here's the compressor I have: https://www.airliftcompany.com/produ...r7qErpPsiefx3x
Here's the tank I was looking to get: https://www.tractorsupply.com/tsc/pr...tyDJGuq68hiWXU
Thanks in advance for your time!
Old Sep 28, 2025 | 08:34 AM
Log Hog Kust'em's Avatar
Log Hog Kust'em
That compressor is so small, I doubt you would find it useful. I looked at pulling the compressor out of my F250 when I sold it and decided it would be better, if I really wanted it, to buy a bigger compressor
Old Sep 28, 2025 | 06:05 PM
BDWSD22's Avatar
BDWSD22
Here's the compressor I have: https://www.airliftcompany.com/products/compressor-systems/wirelessone?srsltid=AfmBOooKuH8WFONviRWRx_uRmecqdx ZAOHbZ14tH-sr7qErpPsiefx3x
Here's the tank I was looking to get: https://www.tractorsupply.com/tsc/product/viair-25-gal-air-tank-six-1-4-npt-ports-200-91028-1383956?srsltid=AfmBOopbQEUOXV8mYIOXUW7nihR_yAMFJZ 9AE21e08ZfXtyDJGuq68hiWXU
As I recall the air bag compressors have selectable air pressure so you don't need a switch. Just plumb the tank into the compressor and it won't know the difference. Also plumb in a quick diconnect for the hose. It should be absolutely simple to do. I use a Campbell Hausefield $30 compressor from Walmart, a regulator and a 1 gal tank from a Mercedes and it works fine when I need it. I also have air bags.
jdadamsjr
Oct 21, 2014 06:40 PM
Trojan8975
Aug 6, 2011 09:08 PM
ghunt
Jan 12, 2008 04:26 PM
ivanribic
Offroad & 4x4
19
Oct 14, 2004 02:37 PM
jaxle
Garage & Workshop
Jun 22, 2003 09:33 AM
