Need help with hubs
Old Sep 20, 2025 | 03:37 PM
NJ_Phil's Avatar
NJ_Phil
Need help with hubs
So I got this truck, One hub has a busted cover and looks like 6 bolt, the other hub is a 3 bolt. Been reading that the 3 bolt version are "automatic" yet I see no wires and a manual actuator so maybe they are not electrically activated. Not sure whast's up with that and why an "auto" hub would have a ****
Regardless, I just want the manual ones unless someone has comments on why the autos are better.
Anyone know the proper Warn number?"
Thanks
1997 f250 HD 8800 GVWR TTB
Old Sep 20, 2025 | 06:09 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Then you also read that the auto hubs are mechanical and engaged when 4wd was selected and the truck moved in either direction. The design flaw is that when the opposite direction was selected the hubs momentarily disengaged and then reengaged.
Top picture the cap is missing but appears to be 3 bolt
Middle picture is clearly a manual hub
Bottom picture irrelevant.
I’d say you probably only need a replacement cap but the bolts are broken off on the hub body. Good luck getting those out.
What part number did you see on Warn’s website?
Old Sep 20, 2025 | 07:18 PM
NJ_Phil's Avatar
NJ_Phil
So you are saying the top pic with the broken cover are also 3 bolt even though there are 6 bolts?
I'd rather just get a new pair and be done with it instead of replacing just the cap. The warn PNs I've seen are:
Warn 140489-03392050 but they are 19 spline which won't fit although they specify 1997 F250 HD but also specify "LIGHT DUTY"
Warn WRN-20990 from Summitt
Warn 5313-03235345 from another retailer
Pretty strange how drastically the part numbering scheme changes
Didn't check the Warn site
Old Sep 20, 2025 | 07:23 PM
My4Fordtrucks
Hard to tell if there are 6 from this angle.
Why not check with the manufacturer first?
Old Sep 20, 2025 | 08:35 PM
NJ_Phil's Avatar
NJ_Phil
I should have
Thank You very much
EDIT-> Actually bought the 38826 Premiums for $290
Old Sep 21, 2025 | 05:17 AM
manicmechanic007's Avatar
manicmechanic007
Dime a dozen at the junkyard for those hub bodies and caps
290 sounds like "list price" or what used to be "installed" price
Old Sep 21, 2025 | 05:22 AM
My4Fordtrucks
Used to be but not so much anymore. Not many vehicles that old show up at the yards near me. Several years ago, I grabbed a couple sets of OEM and Warn premium hubs as well as a set of Mile Marker.
Old Sep 21, 2025 | 06:10 AM
NJ_Phil's Avatar
NJ_Phil
I want my grandson driving this truck around in 2060 so figured I'd stick a new set in there for him.
dylanhampshire24
Nov 16, 2024 12:21 AM
NM76F150
Mar 28, 2023 07:56 AM
Robb10
Jan 7, 2022 09:19 AM
Taylors68fastback
May 10, 2020 09:19 PM
kraylake
Jan 5, 2012 10:54 AM
