Cruise Control Not Working
Sep 17, 2025 | 11:43 AM
I recently replaced a leaky water crossover gasket and when I was all done under the hood I noticed my cruise control wasn’t functioning.
Did I knock something loose perhaps? I checked fuses #46, #76 and #10 (as per a suggestion from a previous thread) and still nothing.
What do y’all think? It’s something super simple, right? 😄
Sep 18, 2025 | 08:02 PM
Likely knocked something loose. Check vacuum lines.
Sep 18, 2025 | 08:29 PM
Identify model year and engine.
Sep 18, 2025 | 09:44 PM
It’s a 2010 F-150, XTR, 5.4 litre, 4x4.
Sep 19, 2025 | 06:27 AM
Quote:
Originally Posted by
wirelessengineer
100% fly-by-wire system, doesn't use vacuum for the speed control. Vacuum speed controls went away in the 90s on Fords.
Sep 19, 2025 | 06:30 AM
BruceJeremy
Do you have a scan tool or comparable that can read PCM PIDs? Need to see what the PCM is "seeing".
For easy stuff, I'd suggest checking operation of the BPP switch.
If the engine drives normally, there's nothing under the hood to knock loose that can affect only the speed control.
Sep 19, 2025 | 02:38 PM
Is Forscan a decent scan tool? I installed the free one-month trial to turn off my tire pressure gauge back in the Spring. Should I re-subscribe and do a test?
Sep 19, 2025 | 04:25 PM
A paid subscription for Forscan, last I checked, is not needed for reading stuff.
KK560
1983 - 2012 Ranger & B-Series
Aug 27, 2025 09:37 AM
Murf-150
1997 - 2003 F150
19
Dec 18, 2024 12:40 PM
nelly781
1978 - 1996 Big Bronco
Jul 11, 2004 07:57 PM
jeepin
Electrical Systems/Wiring
Aug 17, 2003 08:13 PM
BB2
Aerostar
Jun 12, 2001 06:35 PM
