Sponsored by: Auxito
Cruise control
Old Jun 30, 2024 | 10:12 PM
Murf-150's Avatar
Murf-150
Cruise control
My cruise control just stopped working for no reason I can figure out. It’s a 2002 F150 Any thoughts?
Old Jul 1, 2024 | 07:39 AM
projectSHO89's Avatar
projectSHO89
Start by checking the pressure switch on the master cylinder along with the recall harness, if present. Most common failure.
Old Jul 1, 2024 | 05:57 PM
Murf-150's Avatar
Murf-150
Cruise control
Could it also be the control switch on the steering wheel?
Old Jul 1, 2024 | 06:11 PM
projectSHO89
It could be any of a number of things... Start with the most common,.
Old Jul 1, 2024 | 06:55 PM
Murf-150's Avatar
Murf-150
Cruise control
As I was driving to Lowe’s this afternoon I tried the cruise control and it worked for about a minute. I ordered the parts (both) and we’ll see.
Old Jul 1, 2024 | 08:26 PM
RLXXI's Avatar
RLXXI
Your truck is 22 years old. Be thankful it still runs. Just saying.
Old Jul 1, 2024 | 08:37 PM
Murf-150's Avatar
Murf-150
Truth!
You are right! BTW it runs great.😎🇺🇸
Old Jul 2, 2024 | 03:54 AM
manicmechanic007's Avatar
manicmechanic007
The cruise switches are a common problem
Try "laying" on that ON switch and re try it
With a NGS you can read the PIDS from all the speed control switches and test the operation of the BOO switch
Old Jul 2, 2024 | 09:21 AM
Murf-150's Avatar
Murf-150
NGS, PIDS & BOO? I have no idea what that means. Please explain.
Old Jul 2, 2024 | 10:14 AM
RLXXI's Avatar
RLXXI
New Generation Star, it's a Ford scan tool.
Paramater Identification.
Brake On Off.
Old Jul 2, 2024 | 10:33 AM
manicmechanic007
Without the above, you have a hell of a time testing the switches
Same with the actuator
The cable breaks often and the brake lamps need to work
Those are some basics to check
Pull on the cable leading to the servo / actuator, if it pulls out, it's broke
I have no 02 service manuals or EVTM that will explain the circuit and testing methods
That is what you need
AllData has the info (your public library has, or should have AllData free)
Old Jul 2, 2024 | 11:30 AM
projectSHO89
Neither the NGS nor any other scan tool can read the steering wheel switches on the OP's truck since there's no diagnostic tool or network connection to the speed control servo. No PIDs, either...
You have to use a multimeter to test the steering wheel switches, it's pretty simple. The factory service manual has the procedure.
Old Jul 2, 2024 | 03:44 PM
Murf-150's Avatar
Murf-150
Thank you!
Old Jul 2, 2024 | 04:11 PM
truckguy92's Avatar
truckguy92
I had the same thing happened to me and I’m willing to bet it’s the pressure switch in the master cylinder like mine was and is only $30 or so.
there is also a self check you can perform with your check. To enter this self check:
press the off button while turning the key to on. The cruise light should only flash once at this point. Release the off switch. In sequential order press each button after the light flashes: on, resume, coast and set/accel. The light will flash and you need to count them to know where the problem is. If I remember correctly mine was 2 or 3 flashes when I did this two or so years ago. This information was copied from the forum linked in the reply which also has details into what flashes indicate.
edit to add: if you are pressing the buttons and finish the sequence and have no flashes whatsoever, your steering wheel controls are bad.
Old Jul 2, 2024 | 04:24 PM
Murf-150's Avatar
Murf-150
Thanks! I’ll do that.
