My baby needs help.
Old Sep 16, 2025 | 03:40 PM
My_Excursion_Is_A_Princess's Avatar
3rd Gear
My baby needs help.
Good afternoon. I'm hoping one of my fellow Excursion drivers can help me get my Princess Tank back on the road. She is a 2003 V10 6.8L. She Had a bad experience with a mechanic that didn't know what they were doing after I blew one of my heater hose connections that was connected back at the firewall at the heater core connection. I know that I'm probably going to have to MacGyver some parts back correctly but if anybody could take pictures that has been working on their vehicle of how these hoses are supposed to reconnect. I know there is the upper heater hose that connects to the front of the engine into the back but I don't know how it connected back to the heater core and the underside that I provided pictures for I don't know how anything was connected that way back. I appreciate any help. I tried finding a diagram that was showing me the parts but that seems to be very hard to find and I'm kind of limited on videos. Again I just need to see how it's supposed to connect and then I will build whatever I need to myself but I can't tell how these things are supposed to be reconnected. Pictures or video would be great.
Front heater core hose
Where front heater core hose was cut. Not sure what it looks like before it got modified.
Heater core
Heater core
Lower connection that I'm not sure how it connected so that I can get the coolant to flow correctly.
Old Sep 17, 2025 | 03:50 AM
ashleyroachclip's Avatar
ashleyroachclip
The hoses in your picture are for the rear heat I am guessing ?
I do not have an X ,but can tell you , the hoses are a snap lock kind of connection onto the heater core .
Old Sep 17, 2025 | 10:15 AM
oharal's Avatar
oharal
I just went through this when my heater core connections started leaking. Most of the hoses are NLA and some, especially anything related to rear heat is Excursion specific and don't exist anymore that I could find. I also could not find suitable right angle quick connects to mate to the heater core. I had to buy aftermarket straight fittings and use a loop of hose off the heater core so the hoses would not kink up. Spray silicone spray in the new QC fittings and on the ends of the heater core and then have someone push on the heater core from inside the car and they will snap on, Sadly, you won't be able to see what you are doing while you do it.
The water comes out of the cylinder head on the driver side, loops around the back of the engine and comes out then T's off with the hose from the rear heater valve from up front on the engine (I think from the water pump IIRC). the other end of the T leads to one leg of the heater core and the other leg of the heater core goes down to the rear heater core line I think....
Old Sep 17, 2025 | 04:37 PM
3rd Gear
Yeah they are quick connections but won't be finding those.
3rd Gear
Thank you @oharal for that.
Old Sep 17, 2025 | 06:43 PM
01__Excursion's Avatar
01__Excursion
Here is one of the hoses NOS.
https://www.ebay.com/itm/195257370247
Old Sep 18, 2025 | 04:40 PM
oharal's Avatar
oharal
Buy the dorman ones on the shelf at the local parts counter. they'll be in stock.
Old Sep 18, 2025 | 10:49 PM
John in OkieLand's Avatar
John in OkieLand
Similar thread, I would go with Dorman also.
https://www.ford-trucks.com/forums/1...l#post21054648
jasper27
Jul 20, 2023 12:20 PM
bbsitum
1997 - 2003 F150
Jan 20, 2023 01:56 PM
Allan N Polly Knisley
Jul 7, 2020 01:11 PM
victorcharlie
Nov 21, 2011 03:31 AM
frigerator
Sep 10, 2009 11:57 PM
