4r100 shifting problem
Old Sep 19, 2025 | 08:16 AM
Mattestrandgard's Avatar
Mattestrandgard
1st Gear
Hi, I have a Ford Excursion with a 7.3 Powerstroke and a 4R100. I’m having an issue where, when driving, it won’t shift from 2nd to 3rd until it’s almost at the rev limiter, and the shifting feels strange. However, if I lift the rear of the truck and run it, the transmission shifts perfectly. I’ve already swapped in another freshly rebuilt transmission with a new converter. I’ve also replaced the OSS sensor and the MLPS. Today I hooked the truck up to Forscan and checked that I’m getting data from all the sensors, including the VSS. I noticed, however, that according to Forscan my TPS sensor shows a minimum value of 13% and a maximum of 77% at full throttle. Could this be the issue? I’m not getting any trouble codes at all. I live in Sweden and always struggle to get hold of these parts, so it’s getting a bit frustrating. Any help is greatly appreciated, thanks!
Old Sep 19, 2025 | 02:39 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
A few years ago I had a similar problem, the throttle position sensor was causing the transmission to shift sluggishly. I read on here that another user stepped on the pedal to go and it didn't do anything. Out of frustration, he stopped on the pedal repeatedly and that fixed it
LocalOBS
Oct 6, 2024 06:44 PM
96ruby
Jun 29, 2016 10:23 PM
nicke147
Jan 19, 2012 11:17 AM
SuperSlimTony
Jul 10, 2011 05:19 PM
89ford73
Sep 24, 2010 06:26 PM
