2020+ Explorer Discuss the rear-wheel-drive 2020+ Explorer
Auto start disabling
Old Sep 16, 2025 | 07:56 AM
Dazeoff24's Avatar
Dazeoff24
5th Gear
I have a 22 explorer ST line. Any way the auto start can be shut off so I don’t have to keep turning it off every start cycle? Thanks
Old Sep 16, 2025 | 09:40 AM
67galax's Avatar
67galax
Trying to figure this out myself. I haven’t figured out how to disable it at all in my 2021. When I come to a stop, I stop well back and creep forward to keep the motor from shutting off.
Old Sep 17, 2025 | 11:37 AM
2020FordRaptor's Avatar
2020FordRaptor
You can obviously just push the button to turn the system off, but some people don’t like doing that so often. You can disable it via Forscan which I do in this video here:
Old Sep 17, 2025 | 11:55 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
I just push the button as soon as we take off. But yes, creeping forward will keep it running as well as a slight turn of the steering wheel.
I've tracked my mileage both ways and I think it's a load of crap that it saves fuel beyond a negligible amount. I've seen Ford techs online swearing for it and about it.
Old Sep 17, 2025 | 07:24 PM
85e150's Avatar
85e150
Short version:
--must be off for 7 or more seconds to save gas as it takes 7 seconds of gas at idle to start the engine. (count it out--not a lot of 7 second stops most of the time)
--EPA mileage tests are said to gain 1/10th of a MPG. This is also reported by independant tests
--My cousin has a Subaru Crosstrek. He's had it about 18 months. The meter shows him how much time off due to AS/S. And how much gas saved. He's saved about 1.5 gallons.
I know that the computer calculates that but I wonder if it takes into account the 1 or 2 second stops that actually increase gas usage. (stop for 2 seconds, use 7 seconds worth of gas to start)
I just hit the button as part of the start up routine, just like checking the AC and radio volumn.
YMMV.
Old Sep 22, 2025 | 06:49 AM
Dazeoff24's Avatar
Dazeoff24
5th Gear
Guess I’ll need to get Forscan as I have stuff on my F350 to change as well. Is it user friendly? I’m not as good with computers as I used to be and don’t want to mess anything up
Old Sep 22, 2025 | 10:51 AM
2020FordRaptor
Very user friendly, and as long as you follow along with the video above you shouldn’t mess anything up. The biggest thing is saving backups.
Old Sep 30, 2025 | 06:02 PM
67galax's Avatar
67galax
Does all this only apply to the ST? I have a base model. I do have forscan, but the video is also for an ST.
Rmack941
2019 - 2023 Ranger
May 13, 2026 04:02 AM
Tncdrew
Jun 29, 2023 03:37 PM
dkk
2021+ Bronco
17
Jan 15, 2022 12:01 PM
renoduckman
2021+ F150
48
Dec 28, 2021 04:39 PM
JeffD11n
2015 - 2020 F150
65
Sep 21, 2021 07:34 PM
