Custom Rear end?
Old Aug 30, 2025 | 02:16 PM
Moreambitionthentalent's Avatar
4wd High
Custom Rear end?
Ive got an 83 F-250 XL regular cab long bed that has what would appear to be an 8.8 rear end with 8 lugs. Searching the web hasn't done anything but add confusion as most data bases insist it has to be a Dana 60. And Ford never made an 8 lug 8.8....
This axle shows no signs of any customization whatsoever. Anyone ran into this? Am I going to have to start counting splines to figure out what bearings, shims, seals to order 😅 The Truck has an axle code of B6.
Old Aug 30, 2025 | 02:32 PM
85e150's Avatar
85e150
Best I can tell you have a Ford LD 8.8.
8.8 vs. Dana is easy to tell as the rear covers are very different.
https://www.garysgaragemahal.com/axle-ratios.html
https://www.rockauto.com/genImages/AxleID/axleDims.html
Old Aug 30, 2025 | 02:36 PM
4wd High
Yeah It absolutely has the 10 bolt square cover. I know Ford loved to offer oddball combos durring this erra seems like someone would have written something down about it 😅😆
Old Aug 30, 2025 | 02:41 PM
85e150's Avatar
85e150
Considering what a departure it is from the "standard" for 3/4 ton axles** it is surprising you don't see more about it. It should at least be an * in the text and a little note saying "Yes, Ford put 8 lug axles in an 8.8" diff....." .
** "standard for 3/4 ton axles" = Dana 60......
Old Aug 30, 2025 | 02:48 PM
4wd High
Completely agree!
if a fella was just going to assume its an 8.8 what year model should I shoot for since the folks at the part store cannot seem to find anything without YMM...?
Old Aug 30, 2025 | 02:52 PM
Franklin2's Avatar
Franklin2
Here are all the rearend options in 1983 for a F250. You can see yours is the 3rd one from the bottom of the list. A nationwide search reveals they are sprinkled throughout the states, and a used one is very reasonably priced.
semi-floating, Spicer 60-3, 3.54 ratio
semi-floating, Spicer 60-3, 3.73 ratio
semi-floating, Spicer 60-3, 4.10 ratio
semi-floating, Spicer 61-2, 3.00 ratio
semi-floating, Spicer 61-2, 3.07 ratio
semi-floating, Spicer 60-U, 3.54 ratio (ID E3TA-BEA)
full-floating, Spicer 61-1, 133" WB (Pickup), 3.07 ratio
full-floating, Spicer 61-1, 133" WB (Pickup), 3.54 ratio
full-floating, Spicer 61-1, 133" WB (Pickup), 3.73 ratio
full-floating, Spicer 61-1, 133" WB (Pickup), 4.10 ratio
full-floating, Spicer 61-1, 137" WB (chassis cab), 3.07 ratio
full-floating, Spicer 61-1, 137" WB (chassis cab), 3.54 ratio
full-floating, Spicer 61-1, 137" WB (chassis cab), 3.73 ratio
full-floating, Spicer 61-1, 137" WB (chassis cab), 4.10 ratio
full-floating, Spicer 61-1, 155" WB (Pickup), 3.07 ratio
full-floating, Spicer 61-1, 155" WB (Pickup), 3.54 ratio
full-floating, Spicer 61-1, 155" WB (Pickup), 3.73 ratio
full-floating, Spicer 61-1, 155" WB (Pickup), 4.10 ratio
full-floating, Spicer 61-1, 161" WB (chassis cab), 3.07 ratio
full-floating, Spicer 61-1, 161" WB (chassis cab), 3.54 ratio
full-floating, Spicer 61-1, 161" WB (chassis cab), 3.73 ratio
full-floating, Spicer 61-1, 161" WB (chassis cab), 4.10 ratio
full-floating, Spicer 70-U, 133" WB (Pickup), 3.54 ratio
full-floating, Spicer 70-U, 133" WB (Pickup), 4.10 ratio
full-floating, Spicer 70-U, 133" WB (Pickup), 4.56 ratio
full-floating, Spicer 70-U, 137" WB (chassis cab), 3.54 ratio
full-floating, Spicer 70-U, 137" WB (chassis cab), 4.10 ratio
full-floating, Spicer 70-U, 137" WB (chassis cab), 4.56 ratio
full-floating, Spicer 70-U, 155" WB (Pickup), 3.54 ratio
full-floating, Spicer 70-U, 155" WB (Pickup), 4.10 ratio
full-floating, Spicer 70-U, 155" WB (Pickup), 4.56 ratio
full-floating, Spicer 70-U, 161" WB (chassis cab), 3.54 ratio
full-floating, Spicer 70-U, 161" WB (chassis cab), 4.10 ratio
full-floating, Spicer 70-U, 161" WB (chassis cab), 4.56 ratio
semi-floating, Ford manufactured (3.55 ratio)
semi-floating, Spicer 60-U, 3.73 ratio
semi-floating, Spicer 60-U, 4.10 ratio
Old Aug 30, 2025 | 02:54 PM
85e150's Avatar
85e150
Can't they find the right parts under your '83 F250? What is the axle capacity? That should be part of the search as well.
https://www.napaonline.com/en/p/BK_8251166
Not sure that will come up for you but it's just a search of Napa on line for rear axle bearings for '83 F250. They only offer that one kit, so if you had a different axle for that year I guess you have to shop elsewhere.....
It cross references to many other Fords with the 8.8.
Old Aug 30, 2025 | 04:25 PM
FuzzFace2's Avatar
FuzzFace2
I would not use a local parts store for anything like what you are after unless you can get the numbers off the bearings & seals and even then it would have to be a NAPA.
If you are looking to rebuild / change gear ratio(s) give https://www.drivetrainspecialists.com/
A call as they know their stuff as I have used them many times for different cars & trucks, one was my AMC 20 rear axle drag car.
Dave ----
Old Aug 30, 2025 | 04:40 PM
4wd High
You'd think! This is where the it has to be a D60 or 10.63 err whatever its started. I nicely asked if he would please follow me to the parking lot where i showed him what appears to be an 8.8 with 8 lugs (CARQUEST)
Old Aug 30, 2025 | 04:42 PM
4wd High
Awesome thanks!
56fordguy
Sep 1, 2025 12:47 PM
Fordever2
1983 - 2012 Ranger & B-Series
Aug 31, 2005 10:51 PM
davelong667
Feb 27, 2004 08:39 AM
borin&strokin
Nov 24, 2003 06:31 PM
xtrmbkr
Offroad & 4x4
Dec 11, 2001 08:36 PM
