Hole in block
Old Aug 30, 2025 | 10:21 PM
Midwest87's Avatar
Midwest87
A bug in the tuner could easily cause this. A couple whoops injection events, to get fuel in the oil. Or to hurt the injector to cause it to leak on the wrong stroke..... Combine that simple fact with "lightly used retirement truck", and the picture gets worse.
Weve seen minor injector issues, or minor software bugs affecting the injectors, wipe out big 4000 horsepower v16 diesel engines, in no time at all.
Diesels need worked every day, to maintain reliability. You dont have to flog them, just work them. Our trucks that sit, because theyre backup trucks, fail far more often. We keep the gas trucks for that. Auction off the extra diesels.
Should have bought a gas truck. Sorry.
A freind of mine made the same mistake. Tuned a perfectly good truck, and blew it up. Worst part was, he had ordered it with sissy gears. If he would have ordered better axle gears, he would have had more power than the tuned truck. And not killed his warranty.
Old Aug 31, 2025 | 11:27 AM
FishOnOne's Avatar
FishOnOne
Originally Posted by longhaultransport
That sounds like a manufacturing defect.
I doubt an 80HP tune would cause that damage.
Problem with tuning is adding advanced timing on the injection event causing extreme cylinder pressure
Old Sep 2, 2025 | 07:03 AM
99powerstrokedF250's Avatar
99powerstrokedF250
Yep, seen a LOT of threads about tuned trucks blowing up, not as much with the 6.7 but definitely on the 6.0's and 6.4's, where guys removed the EGR then slapped a tune on them and started having issues.
Meanwhile I had one bone-stock 6.0 with rust being its biggest problem, and one that was giving me issues with injectors before I went through and bulletproofed it and added a towing tune. And my dad is STILL driving his bone-stock '08 F450 with a 6.4 and 300k on the clock. Every one of them either daily driven or used often to tow heavy loads...or both.
Old Sep 2, 2025 | 07:26 AM
Stinson1's Avatar
Stinson1
I am in this camp as well. I am not anti tune, but these things do happen used to be really common back in the 7.3 days with one particular tuner on the fuel economy tune. These guys that are tuning do not have the ability to monitor peak cylinder pressures when making timing changes. When the OEM's make a calibration/tuning change all of the critical temps and pressures are checked before releasing the change to ensure reliability and they don't always get it right either.
Old Sep 2, 2025 | 11:37 AM
speakerfritz's Avatar
speakerfritz
No change to the OP's initial 2 posts.
would be good to get an ending to this story
Old Sep 2, 2025 | 11:46 AM
406f150's Avatar
406f150
With the initial post on Friday going into a holiday weekend, we might not hear much of an update until it gets into a shop for a teardown.
Gwilkrrs
Feb 25, 2025 05:18 AM
Aaron296
Oct 2, 2021 11:10 AM
mattdoc88
Sep 27, 2017 05:42 PM
Winchester
Mar 16, 2004 09:04 PM
aprice
Oct 12, 2003 09:30 PM
