windowed block........
Old Feb 24, 2025 | 05:24 AM
Gwilkrrs's Avatar
Gwilkrrs
02 with 195,000
i changed the oil sat and noticed oil over front of motor and underneath. oil then looked grey and metalic-
hmmmm went looking and found this small hole- runs same but something definitely gave up to window the block. thinking of JB welding a patch over the hole to buy some time?
File Type: mov
Old Feb 24, 2025 | 12:46 PM
shorod's Avatar
shorod
You apparently have a lot more confidence in JB Weld than I do. Even if it were to buy you some time, most likely it would chose the exact worst possible time to completely fail and leave you stranded or stuck blocking traffic.
-Rod
Old Feb 24, 2025 | 01:33 PM
aquanaut20's Avatar
aquanaut20
That hole is the chain trying to escape, park it, part it or find a replacement engine..
Old Feb 24, 2025 | 03:58 PM
85e150's Avatar
85e150
If he's trying hard enough to make that hole, he will eventually succeed in leaving...... sooner than you'd like.
Is this a 4.0 SOHC?
Old Feb 25, 2025 | 05:18 AM
Gwilkrrs's Avatar
Gwilkrrs
4.6
i realize that this is the end- just trying to stretch it out a bit and use as around town spare for a bit longer......
Aaron296
Oct 2, 2021 11:10 AM
TMI
Dec 24, 2016 06:46 AM
52runner
Mar 1, 2012 03:16 PM
gsb15
Jun 27, 2011 08:57 AM
fordnjneer
Apr 11, 2005 11:07 AM
