no gas :s
Old Dec 7, 2003 | 02:26 PM
79_ford_400_guy's Avatar
79_ford_400_guy
Angry no gas :s
hi guys ii wanna put an electric fule pump on my truck so i mounted it toward teh back of my truck bout 3 feet from the rear tank.....b4 i started this project my truck wasnt gettin gas and i just thought my fuel poump was in the wrong spot so it couldnt suck gas....so i was gonna mount it in back.....i cut the gas line and no gas comes out....at all nota dribble so theres my reason im gettin no gas...and i looked at the line it aint kinked anywhere.....and the gas tank swich is set on back....could tehre b something wrong with the swich er somthing......?????? thanks kevin gross
Old Dec 7, 2003 | 03:43 PM
clean79150's Avatar
clean79150
I can't tell you why your lines are dry, could be clogged with dirt at the tank, or in the line somewhere, or like you said, your tank switch may not be switching over, maybe a relay.
Why do you want an electric fuel pump anyways? I think that once you get your fuel flowing through your lines that you'll be fine with a mechanical pump, unless your going with some sort of fuel injection system.
Old Dec 7, 2003 | 05:10 PM
freak98's Avatar
freak98
I put a electric fuel pump on mt 78 Bronco here's some pic's if you want to see what I did.
http://www.superford.org/?vID=4037
Old Dec 7, 2003 | 05:35 PM
Texan1983's Avatar
Texan1983
i am running an electric fuel pump in my truck, and it needs to be mounted as close as posible to the tank. there might be no gas in the line because the pump will have a hard time bringin gas into a dry line, work with it a little and try to get some gas coming out. these pumps push fuel, and can't really pull much at all.
Old Dec 7, 2003 | 06:17 PM
clean79150's Avatar
clean79150
Freak98,
That is a sweet Bronco you got there.
Back to the electric fuel pump, what are the advantages of having one?
Old Dec 7, 2003 | 10:08 PM
Torque1st's Avatar
Torque1st
Posting Legend
Make sure you don't have a clogged intake screen in your tank. Also make sure your tank is vented properly.
Old Dec 8, 2003 | 01:52 PM
79_ford_400_guy
ho
how would i check the intake screen were is it?
Old Dec 10, 2003 | 12:49 AM
f100guy's Avatar
f100guy
the reason you have no gas coming out of the tank is because the sending unit has a pickup tube that goes down into the fuel from the tom of the tank it does not gravity feed the fuel lines. the filter screen is at the end of the pickup tube inside the tank
Mason R
Nov 8, 2016 06:31 AM
deisele75
Alternative Fuels, Hybrids & Mileage
18
Jul 2, 2016 06:12 AM
four-sixty-power
Mar 8, 2016 02:51 AM
John Chappelle
Oct 15, 2015 04:20 PM
mcguyver
May 31, 2003 11:56 AM
