General Automotive Discussion
Trans interchangeable
Old Aug 22, 2025 | 09:57 PM
Ceciljon37's Avatar
Ceciljon37
4wd High
I have a 04 f150 heritage 4.6l rwd the transmissions went out it has the two sensors I have a trans out of a 99f150 4.6l rwd I was told the new one has a single sensor and different pcm plug on harness I need to know if it’s possible to get the 99 trans in the 04
Old Aug 23, 2025 | 08:40 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
There are too many differences between a pre-2003 and a post-2003 4R70W to make this swap possible without tearing down the trans and swapping several of the hard parts, plus most of the electronics. Anything is possible, this is not feasible.
Old Aug 23, 2025 | 10:45 PM
Ceciljon37's Avatar
Ceciljon37
4wd High
hey mark thanks for the reply can u tell me what other transmission would be comparable for my truck because finding one affordable with the set up my truck has had really been impossible
Old Aug 24, 2025 | 12:15 PM
Johnny Paycheck's Avatar
Johnny Paycheck
Allegedly, if you have the “1L3P” code transmission, it’s a good bit easier to find a swap donor
The “4L3P” seems to be a 2004 Heritage truck only idea.
https://www.car-part.com/cgi-bin/search.cgi
Old Aug 24, 2025 | 12:35 PM
Mark Kovalsky
I believe that is correct.
Old Aug 26, 2025 | 12:40 AM
Ceciljon37's Avatar
Ceciljon37
4wd High
Where can I check to verify the code I have
Old Aug 26, 2025 | 09:10 AM
Mark Kovalsky
There should be a white tag on the driver's side of the trans with this information.
Old Aug 26, 2025 | 09:24 AM
Ceciljon37's Avatar
Ceciljon37
4wd High
This is the new one  I was going to use out of a 99 f-150
Old Aug 26, 2025 | 09:25 AM
Ceciljon37's Avatar
Ceciljon37
4wd High
Could I use this one from the 99 if I got the pcm reprogrammed
Old Aug 26, 2025 | 01:33 PM
Mark Kovalsky
That says XL3P.
In 2003 the number of holes that the output sensor reads changed. Putting a pre-2003 trans in a 2004 truck is going to cause problems with the speed sensor. The trans will not shift right, if it shifts at all. I recommend not using that transmission, or if you need to use it, rebuild it to 2004 specs.
Old Aug 26, 2025 | 07:14 PM
Ceciljon37's Avatar
Ceciljon37
4wd High
That says XL3P.
you wouldn’t have access to or know where I can get the step by step guide on disassemble and rebuild instructions
Old Aug 26, 2025 | 08:10 PM
Mark Kovalsky
You can get a manual at www.atsg.com
HDWMAN
Modular V8 (4.6L, 5.4L)
Aug 12, 2016 04:37 PM
1320stang
1997 - 2003 F150
Dec 31, 2015 07:34 PM
cordoba1979
2004 - 2008 F150
Jun 14, 2008 03:52 PM
mein2xshp
Mar 18, 2006 05:40 PM
