4R75W TRANS
Old Aug 6, 2014 | 07:57 AM
HDWMAN's Avatar
HDWMAN
4R75W TRANS
I RECENTLY PURCHASED A 04 F150 4X4 WITH 4R75W TRANS THAT WAS SHOT! I BOUGHT A USED TRANS"SAME KIND" INSTALLED AND NOW THE TRUCK WONT SHIFT FROM 1ST-2ND OR 2ND-3RD. WE CHANGED SHIFT SOLENOID STILL SAME PROBLEM. CODES SHOW TSS BUT IT WAS WORKING IN OLD TRANS? HELP?
Old Aug 6, 2014 | 12:25 PM
70f100longbed's Avatar
70f100longbed
IS THE "NEW" TRANS THE SAME YEAR MODEL AS THE OLD ONE? THERE HAVE BEEN A FEW DIFFERENT VERSIONS OF THE SUN SHELL THAT THE TSS READS AND THEY EACH HAVE DIFFERENT PULSES PER REVOLUTION. Ok I can stop yelling now.
Old Aug 6, 2014 | 02:07 PM
HDWMAN's Avatar
HDWMAN
After researching the vin of new trans/truck they r 1 year difference. Old trans from 04, new trans 03! I also took my old front speed sensor out of the old trans and placed it in new one, same location. Could this be the problem and HOW do I fix it?
Old Aug 6, 2014 | 02:21 PM
70f100longbed
You have to take your old trans and new trans apart and swap the reverse sun shell.
Old Aug 6, 2014 | 02:39 PM
HDWMAN's Avatar
HDWMAN
I no longer have my old transmission, it was turned in as core. The new trans has warranty, will i have to drop it and return it? Is this the cause of the trans not shifting at all?
Old Aug 6, 2014 | 03:54 PM
70f100longbed
Yep you will need to return it and get the correct trans.
Old Aug 12, 2016 | 04:37 PM
zidjan's Avatar
zidjan
Hi folks, I know this is an old thread....I am having the same questions but this time is reversed....
Would 4r75e an 06 expedition would work with my 2004 equipped with 4r75w?? I am getting conflicting opinions regarding the "E" uses a sensor call the turbine shaft sensor and critical it is used or will not shift....does this sounds correct?
LUMBERMAN
Jan 14, 2008 09:19 PM
