I'm a new Ranger owner. It's old and so am I
I’m retired. Wife & I got along as a one car family since retirement in 2019. We decided a utility truck would fit the bill as a second vehicle.
I found my Ranger on Craigslist. 185,000 mi.
Am in the process of updating original parts: brakes, front end, serpentine belt…
Any specific things I should replace on a 23 y.o. truck?
Originally Posted by Rusty Bucket Ohio;[url=tel:21642686
21642686[/url]]Welcome … tell us what you have … year, engine, auto or standard, 2wd or 4x4
Sorry, I should have mentioned that.
Here's what I have had done so far:
Brake Service - Rear Drum
Bearing Pack
Brake Fluid Flush
Rear differential Service
Replace Serpentine Belt
Bearing Pack
Brake Fluid Flush
If you have the electric thermostat, if/when it fails, you can replace with a non-electric, and trick the ECM using a resistor. A LOT less $$ to get the engine heating up as it should, otherwise fuel usage wil be higher, and oil will get more moisture that stays.
Check coolant condition along with hoses. The DOHC 2.3 is a pretty good engine, but you likely will have leaks from the cam cover. I am not sure if a new O-ring gasket willl come with the rubber "donuts" for the fasteners, but I think a non-OEM solution is out there. (search)
My truck is 40. I am almost twice that. Hoping to get another 40, but I doubt it.
I would also change the differential lube and transmission lube.
tom
tom
KrAzYKARL
1983 - 2012 Ranger & B-Series
49
Apr 7, 2007 09:29 AM
