So upon using the googler I’m at a loss here I have a 94 350 crew cab with the 460 and a e4OD that has a intermittent shudder and sluggish response feels like I’m driving on a washboard at 50-60 and it’s only happening sometimes and others it hard shifts into limp mode…now part of me tells me it’s just the 240k miles catching up to it but as it’s my daily I can’t really have it go down but also I have a fast turn signal as if i have a bad light yet all are working so wizards of the forum guide me as to my potential problems! Thank you in advance
The next thing to do is to check the trans fluid. Is it full? Low? Overfilled? Red, brown, or black? Does it have a burnt odor?
well I pulled codes finally and found it’s tossing me a VSS sensor so gonna replace that and also turns out had a melted third brake light so I replaced that while I was there so yeah buying a sensor this week and hopefully all my problems there will be solved
