E4OD differences?
Old Oct 27, 2010 | 05:14 PM
hav24wheel's Avatar
hav24wheel
E4OD differences?
What would it take to use a 94 E4OD in a 90 pickup? I was told the 90 E4OD is different than the 94.
Old Oct 27, 2010 | 10:04 PM
Ohio Ford Farm's Avatar
Ohio Ford Farm
I am not 100% but I think Nothing. I know the newer units were built better as ford fixed some of the flaws in the E4OD. I do know there has been a couple threads on this however. You might try searching the old one for some more info.
Old Oct 28, 2010 | 01:55 AM
hav24wheel's Avatar
hav24wheel
I've searched, and read, only thing I found was the shift linkage is prob different between a 90-91 and 92up.
Reason I ask is, I sold(well sorta I guess) my 94 E4OD, the guy bought it for his 90, called me back and said, I won't worK for my pickup. The trans shop told him they are totally different between the two, and "We can't even make it work." WTF! As far as I knew, they where all interchangeable, up to 95, than its a simple plug change on the wiring harness to make it work.
On top of that, he said my trans is 8 inches shorter than his. I'm baffled.
Old Oct 28, 2010 | 03:48 AM
Lazy K's Avatar
Lazy K
I bet his trans is an AOD. Just a guess.
Old Oct 28, 2010 | 03:52 AM
hav24wheel's Avatar
hav24wheel
I don't see ANY stock trans being longer than a E4OD though. Unless this guy is lying to me.
Old Oct 28, 2010 | 04:03 AM
Lazy K's Avatar
Lazy K
Sorry, I misread the post. I thought his was the shorter trans. You are right the E4OD is huge.
If they are both 4x4 transmissions then they should be the same length.
If 4x2 then there may be differences in the tailshaft length.
Old Oct 28, 2010 | 05:03 AM
ford390gashog's Avatar
ford390gashog
The 1990 unit has the speedometer driven from the tailshaft the 94 is from the VSS on the rear axle.
Old Oct 28, 2010 | 07:46 AM
hav24wheel's Avatar
hav24wheel
4x4 trans, so that wouldn't apply.
Gen 1 driver
1978 - 1996 Big Bronco
Oct 24, 2015 08:52 AM
94 Green Beast
33
Jun 20, 2011 06:28 PM
unclemyke
May 3, 2009 11:29 AM
fpyontek
Nov 27, 2006 06:21 PM
