2011 E350 Engine/Fan Noise
Old Jul 30, 2025 | 10:31 AM
5speedjoe's Avatar
5speedjoe
Trailering
2011 E350 350k miles, 5.4L engine. While towing our camper (about 5000 lbs) on the highway at about 62 mph (in 90 degree weather, overdrive always turned off), our van made an intermittent louder noise that almost sounds like the engine revving higher when downshifting while going up a hill, but the tachometer didn’t show any change when this happened. This happened on the trip back from Wisconsin, but not on the trip up. It definitely only did this during the day in the hotter temperatures. And if there was any change in the temperature gage during all this, it was very slight.
I wondered if the fan clutch engaging was making this noise, but it never made that noise on the trip up (although it was a bit cooler—upper 80s). We did get the fan clutch replaced this past January (preventative while changing water pump, etc), but I don’t remember ever having this noise in the past.
Any thoughts? If the fan clutch is faulty, could this cause the fan to be noisier than normal?
Old Jul 30, 2025 | 09:39 PM
BLK79's Avatar
BLK79
Likely fan clutch, sounds like it's operating as needed/intended. They can for sure roar when engaged.
Old Jul 31, 2025 | 04:22 AM
manicmechanic007's Avatar
manicmechanic007
Agree
Likely the fan clutch
When they wear out and start losing the oil inside, it will quit roaring and start overheating
Enjoy that roar, it means the fan clutch "is working for you"
Old Aug 10, 2025 | 01:40 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Agree with the others, from your description, sounds like a happy fan clutch doing its job.
MammaJammaTX
6.7L Power Stroke Diesel
Nov 23, 2020 11:07 PM
spunout
Jun 3, 2010 01:02 PM
andrewsmith
Oct 6, 2007 07:37 AM
baydreamer
All Things Towing
Mar 28, 2005 07:58 PM
johntucker05
Jun 6, 2003 02:17 PM
