Hot start struggles
Old Aug 3, 2025 | 10:03 PM
  #31
Welldressedladd's Avatar
Welldressedladd
3rd Gear
Originally Posted by kr98664
You will want to fix that, regardless of whether the starter needs replacement. You don't want the starter flopping around, secured by only one bolt. This could break off the other ear and/or chew up the flywheel ring gear.
If you remove the one good bolt, the starter should slide off the broken bolt without much trouble. Grab the protruding shank with a pair of Visegrips to unthread it.
It turns out one starter bolt was threaded north to south and the other south to North so no issues there
Here's some related pictures of the exhaust manifold as well as the starters proximity to the exhaust which is why I think heat soak maybe an issue
I'm quite excited to test out the starter but I need another hand and some alligator clips which may be hard to find on a Sunday evening
Current plan is just pop the hood every single yard I do
Old Aug 3, 2025 | 10:05 PM
  #32
Welldressedladd
3rd Gear
  #33
Denzil B's Avatar
Denzil B
So if you turn off the AC and everthing else does that help. You might also want to check your serpintine belt componants and ensure they rotate freely when hot.
Old Aug 3, 2025 | 10:06 PM
  #34
Welldressedladd
3rd Gear
I've seen online that they make wraps that I can wrap around the starter so I might pick one of those out but I will refrain from using the parts catapult just yet.
Old Aug 4, 2025 | 07:33 AM
  #35
Franklin2's Avatar
Franklin2
You do not have headers, so panic is over. You could hardly see the starter if you had headers. They look like this.
Old Aug 4, 2025 | 08:32 AM
  #36
Welldressedladd
3rd Gear
There's about 4 belts on the truck. Which one would I look at?
Old Aug 4, 2025 | 03:06 PM
  #37
FuzzFace2's Avatar
FuzzFace2
All of them but if you turn off AC you would only need to check what else the belt goes over but it could be anything driven by belts and why all of them need to be checked as it can to lock up when hot.
Dave ----
Old Aug 4, 2025 | 03:24 PM
  #38
Welldressedladd
3rd Gear
Dave ----
Bold off you to assume I've got a/c in this old rig it's there but it sure doesn't work
It's been treating me well today so far no slug starts but it hasn't really gotten hot. Lots of overcast. It had a weak battery to block ground i discovered last night. Can I still do the voltage drop test if it isn't hot?
Old Aug 4, 2025 | 03:25 PM
  #39
Welldressedladd
3rd Gear
I indeed was panicking
Old Aug 4, 2025 | 04:13 PM
  #40
FuzzFace2's Avatar
FuzzFace2
At least you have it even if it dose not work.
There is a nut on here that graphed half an AC firewall into a non-AC truck just to have factory AC that has a leak that cant be found yet
The only way to check if it is 1 of the belt driven parts is to undo the belts and check each one.
I dont see why you cant do the drop test when it is not hot but if it checks out good cold then run it hot.
Dave ----
Dave ----
Old Aug 4, 2025 | 04:42 PM
  #41
kr98664's Avatar
kr98664
Yes, but you’ll get more helpful results if you can duplicate the fault conditions.
So a hot engine on a hot day is when the problem is worse, right? You could test the engine hot on a cold day, or the engine cold on a hot day. But for the bestest results, hot on hot will aggravate the fault and make it easier to isolate.
albroswift
22
Aug 3, 2023 10:01 AM
Mantana
May 10, 2016 07:34 PM
dnkensinger
16
Oct 16, 2015 07:30 PM
Nathan Plemons
Jun 23, 2013 11:13 PM
pokerpuller
Aug 24, 2006 02:15 PM
