2014+ Transit 2014+ full size Ford Transit Van, Wagon, Cutaway and Chassis-Cab
2019 transit, abs light, no code thrown
Old Jul 23, 2025 | 06:33 AM
zeroo's Avatar
zeroo
I have a transit and it’s showing the abs light and will also tell you brake assist not available. Plus the traction control won’t turn off when you press the button. I hooked it up to a code reader and to FORScan lite and there are no codes to go by. All wires to wheels look to be in good shape. Any idea where to start? Van is a 2019 250, bare bones work truck.
Old Oct 12, 2025 | 06:27 PM
zeroo's Avatar
zeroo
To update this, i found an obd2 app that does abs, it showed back wheel tuning ring fault. Easy to change, but you need to pull axle. Just jack it up high and you dont lose fluid.
Old Oct 29, 2025 | 02:43 PM
BROWN DOG KTM's Avatar
BROWN DOG KTM
This must be a common problem in Transits.
I’ve read this several times on FB Transit camper build page.
Deagle12
Mar 24, 2018 10:21 AM
mikevv
May 10, 2009 01:01 PM
earl964
Nov 16, 2007 10:23 PM
McGunner
1997 - 2003 F150
Apr 9, 2005 05:30 AM
