ABS warning light on after pothole
Old Mar 21, 2018 | 06:11 PM
Deagle12's Avatar
Deagle12
Hi guys,
For a while now, I get a slight grinding when coming to a stop. Happens when I'm at like 2mph, and I can mitigate it by releasing the brake pedal a bit when almost at the stop.
Not sure if that's relevant, but today the ABS light came on. I hit a big pothole on the freeway, on the driver's side.
I checked the driver's side front wheel sensor and visually it looks fine. I loosened it and re-torqued it. Not exactly sure how to start testing things, and also reluctant to start throwing parts at it.
Anyone have this happen to them? Is there a common cause?
Old Mar 21, 2018 | 10:56 PM
DetroitEx's Avatar
DetroitEx
If you have access to a scanner, check to see what code is being flagged if/since the ABS Light is ON.
Old Mar 21, 2018 | 11:51 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
x2 on the ABS code scan. If you don't want to throw parts at it, get the code. I'm in central Texas. If you can make it to me, we can figure it out quick, and we can get it fixed up for you.
Old Mar 22, 2018 | 07:16 PM
Deagle12's Avatar
Deagle12
Thanks guys. I have a odb2 scanner I use to monitor temps but I don't have any codes. Do I need an obd1 scanner? Will this work?
https://www.amazon.com/INNOVA-3145-Ford-Digital-Reader/dp/B000EW0KHW/ref=br_lf_m_5bkvna52tdhk6yj_ttl?_encoding=UTF8&s=a utomotive
Old Mar 22, 2018 | 07:39 PM
01__Excursion's Avatar
01__Excursion
Have you been continuing to drive it, if so has the ABS light stayed on, or gone off?
Your profile doesn't say anything about what you're driving. How old are your wheel bearing hubs?
My past experiences have shown me that worn hubs, with some play in them will cause the ABS light to come on, too much play or wear in the bearings will cause inaccurate readings/clearances form the ABS sensor to the reluctor wheel.
Old Mar 22, 2018 | 08:30 PM
Deagle12's Avatar
Deagle12
Continuing to drive, ABS light comes pretty much as soon as I get going.
2000 V10, 178k miles, 2wd
Front wheel bearings were replaced by myself when I did the brakes/rotors around 172k. It is possible I didn't torque properly, but I remember it was only like 18in/lb or something.
Old Mar 22, 2018 | 10:55 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
https://www.amazon.com/INNOVA-3145-F...8&s=automotive
The scanner you linked to is not what you need. You need an OBD II unit that will talk to the ABS module. Like this one: https://www.harborfreight.com/ZR11-O...ABS-63807.html
Or you can bring it to me...
Old Mar 22, 2018 | 11:31 PM
Deagle12's Avatar
Deagle12
Thank you, Nicmike, I may take you up on that offer. I'm in the DFW area - might be able to come down over a weekend. Do you have a shop or just a DIYer?
Old Mar 23, 2018 | 12:40 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I'll be though DFW soon. Which side are you on? I usually pass through on the east side going to the farm.
As to the link above, the ZR8 also reads ABS, and it is about $89. Very good reviews on that brand of OBD II scanner.
I am a DIYer with a lot of specialized tools. No shop. Just a garage, driveway and lots of experience turning wrenches.
Old Mar 23, 2018 | 12:33 PM
Deagle12's Avatar
Deagle12
Awesome! I'm a bit west of dallas. I'll PM you.
Old Mar 23, 2018 | 12:44 PM
ncheavymetal's Avatar
ncheavymetal
FTE NC Chapter
Check to see if the connection is tight/good near the fender well. You said you already checked it at the hub.
Also, check to make sure you haven't chafed the line. My tires started chewing into my lines and was giving me an intermittent abs light until it came on completely when the wires were bare.
Old Mar 23, 2018 | 01:00 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Recently found this to be the problem on another members newly purchased X. Road debris took out the connector right behind the driver tire. Destroyed it and part of the fender liner. Previous owner tried to cobble it back together, but failed. We went to the salvage yard, got a new connector for the truck side, and then installed new hubs...which replaced the connector on the hub side. He was back in business with no more ABS light.
Old Mar 23, 2018 | 08:04 PM
carbon coupe's Avatar
carbon coupe
This may sound stupid but I had this issue on another car. Check the sensor and exciter ring for debris. I had a piece of steel/rust stuck to mine and the brakes acted super strange. I took it apart and cleaned everything, finding losts of crap stuck everywhere, and it was fine after that. Just an idea.
Old Mar 24, 2018 | 10:21 AM
wpnaes's Avatar
wpnaes
Wouldn't hurt to check the rear ABS sensor on top of the rear pumpkin. Pull off, inspect connection and clean the magnet.
justin_pistol
1997 - 2003 F150
Dec 23, 2014 05:31 PM
sammie0126
Apr 27, 2014 04:31 PM
86scotty
Sep 23, 2012 11:22 PM
ajordan193
Oct 23, 2006 11:19 PM
McGunner
1997 - 2003 F150
Apr 9, 2005 05:30 AM
