MSD ignition trouble
Old Dec 13, 2003 | 03:41 AM
  #31
Torque1st's Avatar
Torque1st
Posting Legend
When testing an ignition system do not allow the spark to jump distances over that in a spark plug or the excess voltage can weaken some of the components so they will fail later due to moisture (carbon tracking) etc.
You can save yourself a lot of trouble just by using the stock Duraspark ignition system. It is as good or better than the MSD up thru 6000 rpm. It also has a timing retard function to help starting. The OEM system is cheap, parts are readily available, and parts can be tested at any good parts store.
Old Dec 13, 2003 | 12:37 PM
  #32
cid473's Avatar
cid473
msd also sells an ignition box that looks like a factory box, has performance upgrades, has 15 degree manual retard feature, and it plugs into factory harness and is cheaper than a msd6. irun one on my race truck and it pulls strong to over 7000 rpm
Old Dec 21, 2003 | 01:44 PM
  #33
Coondawg's Avatar
Coondawg
Howdy all. I finally got back to fooling with it today. I replaced the magnetic pickup. It starting bumping, but still not enough. The battery was the only thing that hasn't been replaced. I check it and it was 14.4 volts, so I had it checked on a tester at the parts store. It didn't pass the test, so I got a new Marine/RV battery. It helped, but not enough. Apparently, there's just not enough power in the pickup for the ignition.
I reinstalled (glad I left everything in place) the factory box and kept the MSD wires and coil. It hit right off. Idled well, revved well. The MSD Blaster 2 coil works very well. Wish I would have just went with it and the wires.
Anyway, anybody want a MSD 6A box. I'll let it go cheap because I ain't going to buy a MSD distributor!
Old Dec 21, 2003 | 06:24 PM
  #34
There Goes The Neighborhood's Avatar
Coondawg,
Glad to hear everythings going again. The one thing that you can do is bypass the factory coil power wire, and run a direct 12 volts. This will give you as high a power as an MSD. Also, MSD-8778 looks like a stock box, and has performance enhancements of the MSD 6, with a manual retard. This plugs right into the stock harness.
Old Dec 21, 2003 | 08:07 PM
  #35
Coondawg's Avatar
Coondawg
I may consider it later on. Right now any money spent on the truck needs to do interior and body work.
Thanks fellas.
sand1
Sep 4, 2016 07:24 PM
abelmoreno
Mar 27, 2016 07:27 AM
TheKirbyMan
32
Aug 26, 2012 10:02 PM
joe f350
Jun 20, 2011 08:06 AM
mike460
Mar 12, 2003 11:55 AM
