MSD ignition trouble
Old Dec 6, 2003 | 08:13 PM
Coondawg's Avatar
Coondawg
Hey fellas. I've been away awhile and finally got a chance to post again. Unfortunately, under the wrong circumstances.
I finally had a free weekend to myself and decided to install a MSD 6 ignition, coil and wires. I got it all hooked up but the engine won't fire. There is no spark coming from the distributor. I done the test and there is spark going to the distributor.
The distributor is a stock Duraspark with vacuum advance. The wires are MSD Heli-coil, supposedly compatable.
Anyone have any experience with this? Up 'til now the truck has been pretty good since the rebuild.
I'd call MSD but I'll have to wait until Monday.
Old Dec 6, 2003 | 08:34 PM
There Goes The Neighborhood's Avatar
Just curious, and not to be a smart @$$, but did u remember to install the rotor. I've seen it (actually ive done it) before, that's the only reason im asking.
Old Dec 6, 2003 | 08:47 PM
Coondawg's Avatar
Coondawg
Good point. Yes I did put the rotor in. Actually, I suspected the cap and rotor, replaced them both. No change.
Old Dec 6, 2003 | 08:53 PM
Do u mean ur getting spark fom the coil to the distributor, or from the box to the pick-up coil?
Old Dec 6, 2003 | 09:02 PM
Coondawg's Avatar
Coondawg
There's spark coming from the coil wire to the distributor. I unhooked the small wires going from the box to the distributor. Then done the jumper test as MSD's manual says. The box passed the test. I hooked up the wires either way and still get the same result.
I wonder if the MSD manual had me hooking up the right wires from the distributor. They have the black wire not being used.
Old Dec 6, 2003 | 09:08 PM
does your msd have a retard feature? Also if you have another distributor, take the extra distributor and spin it counterclockwise, watching the reluctor wheel as to the position in relation to the pick-up when it fires. You'll need a spark tester to do this. you don't have to remove your distributor from the block to this, if u have an extra.
Old Dec 6, 2003 | 09:16 PM
Coondawg's Avatar
Coondawg
Don't have any of that. Only other thing I can think of is maybe the wires are compatable with the MSD 6. They are MSD wires (Heli-coil) and I was led to believe they will work.
Old Dec 6, 2003 | 09:24 PM
plug wires shouldn't make a difference. Do you have the factory ignition to hook back up? Did you remove the distributor? you may have installed it 180* out. does it kick back when u try to start it, or does it just turn over with no resistance?
Old Dec 6, 2003 | 09:29 PM
Coondawg's Avatar
Coondawg
I didn't remove the distributor. The engine just turns over freely. Heck, I'd be happy if it kick. Then, at least, I would know where to start.
Old Dec 6, 2003 | 09:35 PM
this is a long shot, but is the distributor turning full circle? u could have sheard the pin on the gear. Also try turning the ignition on and jumping the solenoid. Ford powers the box differently while cranking than when in run mode.
Old Dec 6, 2003 | 09:40 PM
Coondawg's Avatar
Coondawg
Yes, the distributor is turning.
Old Dec 6, 2003 | 09:42 PM
did u try jumping the solenoid?
Old Dec 6, 2003 | 09:43 PM
Coondawg's Avatar
Coondawg
No, I had a buddy turning the key.
Old Dec 6, 2003 | 09:48 PM
well, just go out and turn the ignition switch to run. use a screwdriver or remote starter switch to jump the terminals on the solenoid.
Old Dec 8, 2003 | 05:04 PM
Coondawg's Avatar
Coondawg
I just talked to a fella at MSD. He said the problem was most likely the magnetic pick-up in the distributor. I'll take his advice and re-install the factory ignition box and try it. If it runs, there's something wrong in the MSD set up. If it doesn't, I'll replace the pick-up in the distributor.
